Do high tension power line interfere with Wireless
harish.ab
Hello Guys
I have a very basic question
There is 66 KV power line going across the land where i want to set up a wirless and RF id based solution. Do this power line
cause any interference for the communication
Harish
Dennis Kline
Generally speaking, no... you should not expect any interference.  I have extensive use of  wireless from UHF to 30 GHz microwave near high voltage transmission lines without any problems.  It does raise the noise floor, so the S/N radio of your path needs to be watched, but it's not something I would expect to cause you problems.
.....dennis.kline@yahoo.com...(It takes an Act of God to fade a wireless path, but any fool with a backhoe can cut fiber)
Thanks Dennis
I would agree with Dennis. BUT i would use an analyzer to double check.
