EAP client not connect to LAPoint
Hello
from time to time clients EAP cannot connect to three or four points out of 100. At the same time, clients WPA2/PSK can connect to the same points. After the reboot of the problem points, the connection is restored.
On the rest of the points both types of clients (EAP and PSK) work stably.
Additions - output debug on LAP
LAP#debug authentication interface apr1v3 all
% Authentication process for interface apr1v3 not started.
Additions from answers below
1. first there were 1261, then 2602, now 2802.  AP Mode Flexconnect. All model points have the same problem.
2. show wlan (WLAN id) "show wlan.txt" - below
3. WLC - 5520, 8.3.141. (two 5520 HA). show sysinfo.txt - below.
4. users sit in the room under the point - roaming should not be
5. debug client <mac address>      - not yet, but I will do the next accident.
7 Replies 7
AndreaTornaghi
Dear,
which kind of access point are installed on your infrastructure?
which is the model of WLC and firmware?
Also provide:
show wlan (WLAN id)
first there were 1261, then 2602, now 2802. All points have the same problem.
P.S. AP Mode Flexconnect
Is this the clients wont roam to those APs when using EAP auth?
Can you confirm the APs are advertising the EPA SSID?
Are they attempting to associate or not at all?
Can you run the following command:
for one of the clients not connecting to the APs and share
Also provide:
WLC Model, code version: show sysinfo
AP model
*****Help out other by using the rating system and marking answered questions as "Answered"*****
Is this the clients wont roam to those APs when using EAP auth?   - customers sit on the same spot. RCCI of the neighboring point is approximately -70-80, but in the next room there may be problems with local users.
Can you confirm the APs are advertising the EPA SSID? confirm, all points are configured by the same group of points
Also provide:
WLC Model (two 5520 HA), code version: show sysinfo   - show sysinfo.txt
AP model - answer above
There is a small possibility that you are hitting this bug: https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvj41040
Try to disable "FT Over-The-DS mode". I doubt that this is the reason though.
Best would indeed be a client debug …. Everything else looks correct, unless there is an issue with the AP-Group.
did now
FT Over-The-DS mode........................ Disabled
waiting for a repeat of the accident
