efficient solution for checking SSID availability
roberto1234
Community Member
Dear community
I'm facing the challenge that every time our board of directors holds their meeting,
someone needs to be on-site to check the SSID and then log in locally with a laptop to test the functionality.
Do you have any ideas if there's a way to address this within the DNA Center without the need for physical presence on-site?
I'm aware of the Cisco Aironet Active Sensor, but unfortunately, it's reached its end of sale.
Thank you for your assistance.
16 Replies 16
Rich R
The bigger question for me is WHY "someone needs to be on-site to check the SSID"?
What model of WLC, what model of AP, running what version of software?
Have you had it "not working" before?  What was the cause of it "not working" on those occasion(s)?
Is it only the board using those meeting rooms?  Doesn't anybody else use those meeting rooms so they could test it and you cold see them authenticating and generating traffic on the WLC?
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Scott Fella
The sensors really do help, or else you would need to setup some spare laptops or Raspberry Pi so you can remote into or do some testing.  Have you looked into Thousand Eyes and installing an agent on their laptops to collect data?  I think you have various options and tools, including 3rd party tools like 7Signal and others.  We use to keep a few NetAlly devices we can remote into and gather information to, all about cost and what you can and can't do.
-Scott
