EHSA standby Down Issue during WLC 9800 Redundancy
CCC3
As shown in the attached capture, infinite redundancy iteration occurs as EHSA standby down during the redundancy process of 9800.
The version is 17.9.4a.
Do you know anyone?
marce1000
 - Have a checkup of the primary WLC 9800 configuration using the CLI command show tech wireless and feed the output into :
        Wireless Config Analyzer
 - Use the commands below for troubleshooting HA-SSO redundancy :
show redundancy | i ptime|Location|Current Software state|Switchovers
show chassis
show chassis detail
show chassis ha-status local
show chassis ha-status active
show chassis ha-status standby
show chassis rmi
show redundancy
show redundancy history
show redundancy switchover history
show tech wireless redundancy
show redundancy states
show logging process stack_mgr internal to-file bootflash:
 M.
Rich R
Get onto the failed 9800 console and check the current state of the unit then look for crashinfo or core files then open a TAC case providing "show tech wireless" and any crash or core files and the logs from both chassis.
