EWC 9800 | embedded "own" AP does not JOIN (C9120AXE)
Schmoebel
I have reflashed a Cisco 9120AXE (I did it before to other APs aswell) with a Cisco EWC-AP Firmware.
Firmware Package: C9800-AP-universalk9.17.09.04a   which includes:
>> EWC-Image:  C9800-AP-iosxe-wlc.bin
>> AP Image: ap1g7  ( C9115, C9120 )
The "EWC" Part has the IP 172.17.48.8
The "AP" Part has the IP 172.17.50.32
Note: This is the same Hardware which has "2" firmwares - EWC and AP .
Note2: They are in the same subnet 172.17.48.0/20
If I set the TFTP Server to the EWC (172.17.48.8) itself, the Download for its own / embedded AP fails.
conf t
wireless profile image-download default
 description "default image download profile"
 image-download-mode tftp
  tftp-image-path /
  tftp-image-server 172.17.48.8
 do wr
Dec  8 08:36:08.649:
%INSTALL-5-INSTALL_START_INFO: Chassis 1 R0/0: install_engine: Started install add tftp://172.17.48.8//ap1g7
Dec  8 08:36:49.904:
%CAPWAPAC_SMGR_TRACE_MESSAGE-5-AP_JOIN_DISJOIN: Chassis 1 R0/0: wncd: AP Event: AP Name: APA488.7389.5438 Mac: a488.73be.a1c0 Session-IP: 172.17.50.32[5253] 172.17.48.8[5246] Disjoined Image Download Failed
If I change the TFTP Server to my Test-Notebook (172.17.48.217) which holds the needed Images something very strange happens:
The Image for the "embedded" AP starts to download immediatly, as soon as the download finishes the whole AP Reboots with both "sides / parts" (the EWC part and the AP part)
conf t
  tftp-image-path /
  tftp-image-server 172.17.48.217
Dec  8 08:52:23.171:
%INSTALL-5-INSTALL_START_INFO: Chassis 1 R0/0: install_engine: Started install add tftp://172.17.48.217//ap1g7
Dec  8 08:52:50.895:
%INSTALL-5-INSTALL_COMPLETED_INFO: Chassis 1 R0/0: install_engine: Completed install add tftp://172.17.48.217//ap1g7
Dec  8 08:54:13.969:
%CAPWAPAC_SMGR_TRACE_MESSAGE-5-AP_JOIN_DISJOIN: Chassis 1 R0/0: wncd: AP Event: AP Name: APA488.7389.5438 Mac: a488.73be.a1c0 Session-IP: 172.17.50.32[5253] 172.17.48.8[5246] Disjoined Image Download Success
And after  successful download  the EWC and the EWC-AP are rebooting but still cannot join the EWC-AP to the Controller.
This than happens in a endless loop.... until I make the tftp server unavailable again...
19 Replies 19
Cable works for other APs.
Yeah, i bought it 2020 already ... it was one of the first ones... **bleep**.
Any idee how I can go into uboot? It does not take any ESC Keys etc.
RMA Try different baud rates like 115200 as @Schmoebel found works.
My colleague had to do with u-boot devices (not CISCO)  for years and he told me to try boud rate 115200. ...
It worked ... he said, sometimes it happens that the U-Boot  wants 115200 ...
I am currently reflashing it now.
Schmoebel
I am happy that I told you something you not knew
I got my EWC AP working now ... even with Version 17.13.1
Thank you for your help
