07-01-2022 04:34 AM
i have an AP C9120axe in EWC mode.
I want to install virtualized 9800CL WLC Controller on hyperv, and set as HA Memeber.
Is it possible, they can work together?
The EWC in the AP is configured yet, hot to add now the 9800 WLC into the configuration?
TY
07-01-2022 04:51 AM
I do not believe that supported as per i know :
check this guide and limitation :
07-01-2022 04:52 AM - edited 07-01-2022 04:06 PM
They can work as primary and secondary but not as HA, for HA you need same set of hardware, software or VM on both pairs.
07-01-2022 03:05 PM
Follow this guide to complete your EWC configuration. Once set up you can access WLC using different IP to the AP IP itself.
Regarding HA, it is not possible to have EWC and 9800-CL (virtual) in a HA pair. HA only works with the same hardware model(9800-80 or two 9800-40, cannot mix 80 & 40 in HA) or the same virtual models.
Rasika
*** Pls rate all useful responses ***
07-20-2022 05:25 PM
EWC and WLC are not supported on the same vlan. The AP could work in CAPWAP mode with the WLC.
07-21-2022 12:17 AM
- You can only do HA between same models , albeit virtual or not.
M.
