Fab Mode APs - Wireless Client Authentication Sessions on switch int
StevieC666
Level 3
Level 3
Hi all, hoping that somebody out there might have seen something similar to what we're currently experiencing?
Basically, we are seeing issues whereby clients are associating to a SSID configured for 802.1x, being authenticated successfully (ISE Policy Set filtering on the WLC) and then allowed connection to the appropriate network as per defined VNID... However, at some point after that authentication, approx 45mins according to support chaps the users report a loss of connectivity and have to connect to the wired network.
This is where it gets interesting, when we look in ISE we can see that the clients wireless MAC address is now hitting authentication policies within a policy set that is filtered on the Switch hostnames and where the MAB request is coming from the switch interface where the AP is configured. This means that we see a load of MACs on the switch port;
After extensive searching I've found a bug CSCwb87363 : Bug Search Tool (cisco.com) which appears to be along similar lines however there's no detail.
We've had a TAC case open for this whereby it was intimated that there was an ISE policy configuration issue, I've guided my support colleagues to go back to TAC with the above bug reference.
The affected users if they physically roam to another AP immediately authenticate and get onboarded as expected, I'm not sure if the problem follows them around as we've not ascertained that.
Rich R
I see you never got a reply to this - hopefully you've solved it now.
But you're quite right it's a bug - which CSCwb87363 is pointing to now - https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwb68720
It's fixed in 17.6.4 which I'd recommend anyway.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
Hi Rich, thanks so much for pointing us in this direction.
We're currently running 17.6.3 so the bugfix note aligns perfectly. We've been guided by TAC to go to higher release for another issue we have related to RSSI value collection so we're going to reach out to TAC in regards to this case to give them a chance to confirm formally that this bugfix relates to the issue and will be covered in the suggested release.
Will update this once confirmed 👍
