Few radius logs are missing while searching for them in report
Bvbharath
Beginner
Beginner
I was looking for old logs in Cisco ISE (2.2version)of a specific user and when i have tried i wasn't able to find any logs as infact I know that there were many failed authentication of him yesterday but when i go to report and search them in Radius authentication logs i am not finding a single log of his and many other users.
Is this a known bug? And how to resolve this issue?
balaji.bandi
VIP Community Legend VIP Community Legend
is this only for this users, not any logs?
BB
No it's for many user's.
Rich R
VIP Advisor VIP Advisor
VIP Advisor
Yes there were definitely bugs that caused no logging - we encountered that with TACACS so probably also affects radius logs.  We had to upgrade and I think TAC also had to fix something in the database.  Best to make sure you're upgraded to the latest release and if still not working then contact TAC and they'll help you fix it.
___________________________________________
TAC recommended codes for AireOS WLC's
Best Practices for AireOS WLC's
TAC recommended codes for 9800 WLC's
Best Practices for 9800 WLC's
Cisco Wireless compatibility matrix
Field Notice: FN-72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Recommended
WARNING - see CSCwd37092 - 2800/3800/4800 series throughput degraded after upgrading to 8.10.181.0/17.3.6
- The fix for CSCwd37092 is in 8.10.183.0 or rather 8.10.185.0 and for 9800 17.3.6+APSP2 or rather 17.3.7
Field Notice: FN-63942 Lightweight APs and WLCs Fail to Create CAPWAP Connections Due to Certificate
      Expiration - Software Upgrade Recommended
Field Notice: FN-72524 - During Software Upgrade/Downgrade IOS APs Might Remain in Downloading State
     After 4 Dec 2022 Due to Certificate Expiration - Fixed in 8.10.183.0/8.10.185.0 and 17.3.6+APSP5/17.3.7
     Also fixed in 8.5.182.7 (8.5 mainline) and 8.5.182.105 (8.5 IRCM) if you can't upgrade to 8.10
     TAC confirmed that subordinate Mobility Express APs downloading by TFTP are not affected so ME 8.5.182.0 still works
     Note that 8.10.181.0 and 8.10.182.0 have been deferred (withdrawn) and are effectively unsupported by Cisco
Leo Laohoo's list of bugs affecting 2800/3800/4800/1560 APs
Richard R
There are also some bugs causing ISE to log with dates thousands of years in the future so you can't find them because the date is wrong.  Again you need TAC assistance (and fixed software version) to resolve this because it definitely requires a reset on the database which TAC will do for you.
And there's this one https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvg95454 - needs latest software release to resolve.
Richard R
Recognize Your Peers
