Firmware Question
TKOcow
Community Member
This is a long shot, but I got my hands on a few AIR-AP1250AG-A-K9 access points. Got these from a private sale and looking to get the autonomous firmware files by chance?
Can't seem to find them on the website as these AP's are almost a decade old but might not be looking hard enough.
I don't have a Cisco Key or plan at all so Tech Support is unable to get me an engineer. But said here is a good place to start.
First post, hopefully I got all the labels and things right. Thank you to anyone who helps out in advance!
@TKOcow hi, this model is not supported anymore. you can try luck search in google. but cannot guarantee the integrity of the OS. or try contacting who had this model in past times such as local cisco partner.
Good luck
KB
Good luck
KB
after some looking, I found what I needed. Guess I wasn't looking hard enough to begin with. thank you!
balaji.bandi
Product EOL so you wont be so Luck to get from cisco and also buying gray area cisco do not support.
if you know the firmware name and try your luck in google.com you see many downloads, (download and test your luck) - example c1250-k9w7 file name
you can use below guide :
https://mrncciew.com/2012/10/20/lightweight-to-autonomous-conversion/
BB
jagan.chowdam
The Cisco Aironet 1250 Series has been retired and is no longer supported.
  • End-of-Sale Date: 2012-01-30
  • End-of-Support Date: 2017-01-31
EoL notification: https://www.cisco.com/c/en/us/obsolete/wireless/cisco-aironet-1250-series.html
Cisco no longer supports this AP model, and its software image is also unavailable for download through the Cisco Software Download Center.
Your best option may be to search on Google or reach out to your local Cisco Partner, as they may still have a copy of the software for this AP model.
Jagan Chowdam
/**Pls rate useful responses**/
