Flex Connect AP
hs08
my WLC located in Datacenter and AP located in branch office. The AP using flex connect so the client will get ip from local switch in branch office. With flex connect scenario is the data interface on WLC will be used, or flex connect only need connect to the WLC management interface only?
8 Replies 8
balaji.bandi
Local Switching: FlexConnect mode allows access points (APs) to switch client data traffic locally rather than tunneling it back to the WLC. This reduces WAN bandwidth usage and minimizes latency for local traffic.
check the flows :
https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/213945-understand-flexconnect-on-9800-wireless.html
BB
so any interfaces (except management) is not used, am i right?
ammahend
it depends on how you have configured it, even with flexconnect you can setup DHCP traffic to be central.
under policy profile>general>Central DHCP > toggle this button ON or OFF to control this behavior.
-hope this helps-
the dhcp also configured in local site.
Short answer - YES.
If you're using local switching and DHCP then there won't be any "data" (client) interface configured on the WLC anyway.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
Correct, other interfaces will not be used, as mentioned the management interface will still be used to deliver other traffic like central authentication, AP registration etc.
-hope this helps-
Scott Fella
The access points still need to communicate with the controller using the management/wireless management.  The controller is the brains for RRM  as an example.  As long as you have the access points as FlexConnect local switching, then user traffic will egress out the switch the access point is connected to. You can find this on the FlexConnect guide if you are using AireOS or the 9800's.
-Scott
Scott Fella
Maybe take a look at this guide, might help you understand what is being sent to the controller vs the swtich.
Locally-switched WLANs map wireless user traffic to discrete VLANs via 802.1Q trunking, either to an adjacent router or switch. If so desired, one or more WLANs can be mapped to the same local 802.1Q VLAN. A branch user, who is associated to a local switched WLAN, has their traffic forwarded by the on-site router. Traffic destined off-site (to the central site) is forwarded as standard IP packets by the branch router. All AP control/management-related traffic is sent to the centralized Wireless LAN Controller (WLC) separately via Control and Provisioning of Wireless Access Points protocol (CAPWAP).
https://www.cisco.com/c/dam/en/us/td/docs/wireless/controller/technotes/8-5/cisco-enterprise-mobility-design-guide-8-5.pdf
-Scott
