Flexconnect Native (AP management) and Data VLAN can be the same ?
hakim.salleh
I plan to local switching 2 SSID by mapping to two local VLAN
Data SSID = WLAN_A
Device SSID = WLAN_B
Data VLAN = 10
Device VLAN = 20
But I don't plan to introduce new native VLAN for AP Management, will it work if I just use Data VLAN set as native (to be the AP management as well) ?
WLAN_A map to VLAN 10
WLAN_B map to VLAN 20
Native VLAN map to VLAN 10
switchport native vlan 10
switchport allowed vlan 10,20
Divya
Hi Hakim,
I understand that you have two WLAN_A & B on VLAN 10 & 20 respectively. And you would like to use the VLAN 10 as AP Management as well.
In that case, the above configuration mentioned is correct. But as you know, the frames on native VLAN sends/receives untagged. Hence, here the traffic on VLAN 10 will be untagged. However, this won't break the Flex connect functionality.
Divya
Thank you Divp,
So VLAN 10 leaving the switch entering the AP will be untagged, I guess this would not break the FlexConnect but user data traffic would not be routed to WLAN_A properly..
