getting DTLS issues for AP AIR-AP3802I-Z-K9
Noovi
Hi Guys,
i am getting lot of issues for Cisco APs of model AIR-AP3802I-Z-K9 for DTLS connection issues.
*osapiBsnTimer: XX 0X 09:22:38.271: %DTLS-3-HANDSHAKE_FAILURE: openssl_dtls.c:3191 Failed to complete DTLS handshake with peer X.X.X.X
Anything known issues for this mentioned AP?
i have already disabled
 config ap cert-expiry-ignore mic disable
 config ap cert-expiry-ignore ssc disable
WLC Details : Cisco 5508 with image 8.3.143.0
marce1000
        - Could you use :
config ap cert-expiry-ignore mic enable
config ap cert-expiry-ignore ssc enable
         instead ,
 M.
jagan.chowdam
(WLC)>config ap cert-expiry-ignore {mic|ssc} enable
Arshad Safrulla
Make sure that the Dynamic AP management is enabled under the interface in WLC. If you have a pre-defined AP manager interface make sure that the dhcp option 43 is configured to advertise that. If not try priming the AP manualy.
Also make sure that the NTP us updated in the WLC and port required for capwap communication is allowed between the AP and WLC.
