Guest-wired access connections drop every 1- 2 minutes
michael.lussier
I have an interesting problem.
My connections to the guest wired access drop consistanly every 1 -2 minutes. There are no drops in the mobility between the WiSM and the 4402 anchor in the DMZ.  DHCp is served from the 4402 DMZ controller as well as thier authentication.
When a user connects to the guest wired access vlan some times they obtain a 169.X.X.X address and after several tries they get the proper 192.168.x.x addres. The user get thier IP address and get the redirect login. They maintain thier internet connection for only 1 - 2 minutes.
DHCP on the 4402 is set for 4hours
Any thoughts ?
Mike
0 Replies 0
