Help with Cisco Wireless phone 7925g
peter sithole
is there someone who has the knowwledge of installing and configuring cisco wireless phone 7925g. i have CME on my network, Wireless controller 4400, and light weight AP 2600, i would be grateful if there is someone who can help me how to deploy these phones thank you
Hi Peter,
As Scott said, you need to get someone's assistance who has experience in deploying voice over wireless network.This consist of few things
1. RF coverage (~20% overlapping coverage preferably in 5GHz band)
2. CME configuration
3. WLC configuration to support VoWLAN
4. Optimizations (Roaming/etc)
Here is some references you can go through
1. http://mrncciew.com/2013/07/26/how-to-configure-cme/
2. http://mrncciew.com/2012/12/26/top-10-recommendations-for-vowifi/
3. http://mrncciew.com/2013/05/05/wlc-config-for-vowlan/
4. http://mrncciew.com/2012/11/28/understanding-wireless-qos-part-1/
Rasika
**** Pls rate all useful respones ****
Scott Fella
You really need to get a Cisco partner to help you with your install. It's almost impossible to tell you step by step what you need to do in order to have everything functioning well.
The only thing you can do is look at guide for CME and the 7925g.
http://www.cisco.com/en/US/products/hw/phones/ps379/products_implementation_design_guides_list.html
-Scott
Hi Peter,
Rasika
Thanks gents
For all the help i manage to use the Phones 7925g with Cisco vWLC.
Leo Laohoo
Hold on ... This will not work.  The last firmware for the 4400 is 7.0.240.X and this version alone will NOT support 2600.  You will need to look at something like the WLc 5508.
