How many 2500 Wireless Controllers Can I Have
tparrettcisco
I have 5 APs on my network being controlled by a 2500 controller.  I need to add another AP.  Can I add a second 2500 controller for additional APs?
PETER MOOREY
Cisco 2504 WLC supports up to 75 APs.  If your current WLC only has 5 licenses you can purchase and install an 'adder' license (Additive Capacity Upgrade License) to increase the capacity of your existing WLC.
Below is a link to the Cisco 2504 data sheet containing part numbers for adder licenses.
http://www.cisco.com/c/en/us/products/collateral/wireless/2500-series-wireless-controllers/data_sheet_c78-645111.html
To add one extra license order either combination below, depending on whether you want e-delivery or paper certificate:
'L-LIC-CT2504-UPG' AND
'L-LIC-CT2504-1A' 1 Access Point Adder License for Cisco 2504 Wireless Controller (e-Delivery)
OR
'LIC-CT2504-1A' 1 Access Point Adder License for Cisco 2504 Wireless Controller (Paper Certificate - U.S. Mail)
Note- the larger the license units the lower the cost, so buying 1x 25 unit license is significantly cheaper than buying 25 x1 unit licenses.
Hope this helps,
Pete.
PETER MOOREY
OR
Hope this helps,
Pete.
+5 Peter !
I would only add if you go 50+ aps and you are looking to push some bandwidth you may want to consider a 5508 or flex connect your aps. Driving a lot of ap traffic to that little guy could impact low latency applications.
Not just my 2 cents. But my own personal observation.
