how to convert AIR-AP1041N (autonomus) to AIR-LAP1041N (lwapp)
some days ago I succesfully converted  AIR-LAP1041N (lwapp) to AIR-AP1041N (autonomus).
I used  c1140-k9w7-tar.124-25d.JA1.tar which is available to download in Download Software Section for this AP.
But there are any autonomus to lightweigt firmware for this AP.
I tried to use  c1140-rcvk9w8-tar.124-21a.JA2.tar for 1140 but AP hungs after that.
How can i back to LWAPP version in 1041?
7 Replies 7
Surendra BG
Image is correct but i am not sure how exactly ue converting the Autonomous to LWAPP.. hungs means wat?/
Surendra
Surendra BG
converting by command:
archive download-sw /overwrite /force-reload tftp://IP/c1140-rcvk9w8-tar.124-21a.JX.tar
after reboot i see on console:
lashfs[0]: 8 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 32385024
flashfs[0]: Bytes used: 2371072
flashfs[0]: Bytes available: 30013952
flashfs[0]: flashfs fsck took 22 seconds.
Reading cookie from system serial eeprom...Done
Base Ethernet MAC address: 30:e4:db:ab:4f:3a
Ethernet speed is 100 Mb - HALF duplex
Loading "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx"...#########################################################################################################################################################################################################################
File "flash:/c1140-rcvk9w8-mx/c1140-rcvk9w8-mx" uncompressed and installed, entry point: 0x4000
executing...
enet halted
ŔŔŔŔŔŔŔŔŔŔŔŔŔ$/ěçďä/÷Řč/ěČÔ...
and then more lines like :"ŔŔŔŔŔŔŔŔŔŔŔŔŔ$/ěçďä/÷Řč/ěČÔ"
wat does the console logs say??
Surendra
Surendra BG
this is what can i see on the console:
executing...
enet halted
ŔŔŔŔŔŔŔŔŔŔŔŔŔ&/îçďä/÷Řč/ěČÔÓďěĐďçô3Ď/ěÜě/ěŘŔČ/ďŕ÷4Ç/ďÓď÷÷óÜ÷ÜŔČ/÷ÜÇ÷÷ÜëĎ/ěŔÄ/ďĐ/ěŔď÷ďËĎĎ÷7ËĎ÷ďŔÓď/đĂç/ďÄĎ÷3ÇďŔčď÷ÜËďďć/÷Řč/÷÷÷ÜŔĂďÜÜËďŔĚď÷Üč÷Ü÷÷ŢÜëĎ/Ď/ďěä/÷ĐÇ/óÜ÷ěŔč÷3Ŕď÷7Ű/ěäď/÷0ŘÜĐß/÷/ďč/ěäÜÔßĎîčďďĂĎ/ěŔŰŔ$/ěçďä/÷Řč/ěČ/đĂ$/÷ěĐďçÜŘŘ//ďç/ěŔĂďŔ
/Ď;ÜÜËďĎóÜçäÜäćďŰăóŔĂĎ÷ěŔç/ďÄ/Ď/ďěä/÷ĐÇoóóÓŔĐÓ/÷ŔßĎěŔč÷3Ŕ$/÷ěĐďçÜ÷÷ëËď÷÷4Ç/÷čĂďĂÜĎ÷îŔď÷7ŕ/ďč/ěä/đĂ'ď÷ěčďďĂĎ/ěŔÇ÷0ëď/ěŔĂďĎčĎ;ÔŔç/ěÇĎóĚëäÜääďŰďŕăçÜŔŔŔŔŔŔŔŔŔŔÇ/÷ÜÇď÷ÜÔóďďË/÷ÜŘŔĎ÷ŘÜŔŔŔŔŔŔŔŔŔŔăďŕŔ//ěçďŔ(/ď/÷0Üčä/÷ďË/đĂŔŔŔŔŔŔŔŔŔŔŔ'/Ď÷Óßď/ěŘŔ/÷4Ěď÷ÜÜ/÷0ŔóëăçčŰăďŕěÜÇď÷ÜôôÔŔ'ď÷ěčďďĂĎ/ěŘŔ/ŢçŕŔ'ď÷ěčďďĂĎ/ěŔĐ/ÜçŕŰ$ďĎë/ÜëđŰóëËĎď/÷÷÷ÜĚÜčĐäăĂ/óÓ0óÔ
but i connected this AP to dhcp server i see that AP recived IP address from DHCP i tries to search conntroller (i can see frames from AP in wireshark, req to DHCP for CISCO-CAPWAP-CONTROLLER).
so in next days i will try to connect AP to the controller (wlc is in different site, without vpn connectivity).
i think that AP is bad, because of this "weirid chars" on console, but maybe when ap updates firmware from wlc, it will be OK.
thanks for help for now.
If ur using the Hyperterminal.. go fo rthe right baud rates or restore defaults settings... i dont think there is an issue with the AP hardware.. try downloading the software again from the website and retry the process.. and another thing is.. see if it regusters ti the WLC!!
Surendra
Surendra BG
theophile
Hello, I've the same problem, did you find a solution?
Theo
mourad lafjer
First of all, exuse my poor english, i've faced the same problem while trying to convert 8 CISCO 1042n from Autonomous to LWAP.
Tthis morning i managed to fix it by trying to do the conversion with an old version of the IOS.
This it the first ios i tried to convert the AP with c1140-rcvk9w8-tar.124-21a.JX but failed, then i tried with this one
c1140-rcvk9w8-tar.124-23c.JA and every thing worked fine.
Regards.
LAFJER Mourad.
