HQ WLC 5520and branch WLC 2504, branch as primary and HQ as secondary
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
03-21-2018 11:46 PM - edited 07-05-2021 08:25 AM
WLC 5520 installed in HQ, i have got WLC 2504 at the remote site, i need to configure the SSID same as HQ at the branch using the WLC 2504, if the branch WLC failed i need the AP to be part of the HQ WLC as backup WLC. how possible is this design. we had bought the branch WLC and AP..
- Labels:
Wireless LAN Controller
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-22-2018 12:48 AM
HA SSO which is the best approach will not be possible for you. You should have same hardware in both ends. Further more, 2504 doesn't suposup SSO.
But you can have N + 1 HA, for example. This redundant method is not good as SSO but is better than nothing. If one WLC drops, AP will migrate to the other site with a small downtime period.
You can find config example here:
-If I helped you somehow, please, rate it as useful.-
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
03-22-2018 12:53 AM
hi noted on your feedback, will try to run thru you document and comment if required any assistance.
