HTTPS access to Wireless controller works wrong over VPN after upgrade
m-karasek
Frequent Visitor
Frequent Visitor
It happens second time to me, on two platforms. WISM2 and WLC5508.
After some minor upgrade HTTPS access to admi web-gui starts working wrong.
In this last case it was after the upgrade from 8.5.140.0 to 8.5.161.0
webpages starts loading incomplete, or timeouts sometimes, but after few refreshes it loads complete.
Sometimes it loads without problem at a first time.
This happens just when i'm connected over VPN. But before upgrade it works well through thit connection.
Also http access works well before or after upgrade, but it's not ideal way to administrate it. (ssh also works good)
I gues it can be MTU problem, but haven't found any posisbility to tune MTU for the web interface, and
modifying the global MSS for CAPWAP doesn't help.
Does anybody have the same problem or its sollution?
Thank you
Martin Karásek
pieterh
try clearing your browser cache first!
this is mentioned in most release notes when doing an upgrade
especially with minor upgrades where cached modules are "almost" the same........
patoberli
You happen to use Chrome? I have the same issue and switched to Edge. I am typically to lazy to clear the cache, so I assume that's the source of the problem.
Or if you have https redirection enabled ... https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/115951-web-auth-wlc-guide-00.html
"Be aware that this is resource consuming for the WLC in case many HTTPS requests are sent. It is advised not to use this feature before WLC version 8.7 where the scalability of this feature was enhanced."
See the link for more detail but it has dreadfully poor performance.
It doesn't only affect webauth requests, it also severely degrades the management GUI causing exactly the symptoms you describe.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
