HTTPS issue on Aironet 2702i in autonomous mode
franckehret
Level 2
Level 2
Hi there,
Since a couple of months (no real need the first I've seen this issue), I've noticed I could not connect to my Aironet 2702i in HTTPS.
It either shows on Chrome the NET::ERR_CERT_AUTHORITY_INVALID error in a loop mode (I can't continue to the website as I always did, it just comes back to the same state) or displays that I can't get access to the webpage on IE or Edge.
As a workarround I re-activated http and I could manage to update it to version ap3g2-k9w7-xx.153-3.JJ1 but this didn't solve anything. It is probably due to an outdated cypher or protocol.
Does anybody has a solution for that ? An even better option for me would be to be able to import a certificate from my own internal CA, but I already know there is no option in web GUI.
In advance, many thanks for your help ! 🙂
patoberli
Don't use the webinterface 🙂
Never used it (before ME) and can't really help.
You can use to create a new certificate (make sure the clock is correct on the AP!!! use NTP):
crypto key generate rsa general-keys
Then reload the AP and I think it should use the new certificate (which is still invalid in the browser, as it's self-signed).
Well, at the end of the day as I moved to our new home, I've deployed ME with 2 extra APs 🙂
(and converted this AP to CAPWAP)
I had 2x2802i waiting for a long time, but I wasn't happy with the performances of file transfer. As I did review the entire network settings during the move, my guess is that ME was not really happy on a L3 switch (SG500). I switched back to L2 mode as I wasn't using it anyway and everything is working perfectly now.
But maybe this perf issue was also related to buggy ME versions... 😛
Sandeep Choudhary
please also try
1. with other Browser (IE /FIrefox).
2. Reset Chrome/ Update to the newest version
Dont forget to rate helpful posts
