I have two AP, and want an ssid to one AP o and other ssid to other
mplaksin0
In a WLC 5508, i have one AP in first floor and other AP in second floor. I create two WLANS but i need to publish one in first floor and the other in second floor.
Is this posible?
Well Honestly , it depends on the WLC version that you are using.
In olde releases this has to be implemented using wlan override
feature where you need to go to wireless --> Access Points --> Radios --> select either 802.11b or a  --> on each AP there is a blue arrow adjacent to it where you can hover over it and select configure.
In the resulting page there ssid override option that you can enable and select the SSIDs that should be broadcasted on that AP.
On the new releases this has been combined in AP groups so you configure lets say AP group for floor one and another one for floor 2 , in the first one u add the ssids that should appear on floor 1 and the list of APs in that floor.
Then you do the same in the second group.
Mohammad Aldehnee
Don't forget to rate answers that you find useful
7 Replies 7
Surendra BG
yes this can be done.. This feature is called AP-Grouping.. here is the configuration example to perform the same..
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008073c723.shtml
Lemme know if this answered your question..
Surendra
Please dont forget to rate the usefull post which answered your question or was helpfull
Surendra BG
Hello Surendra,
I see the configuration example, but i think that Ap Group Vlan is to publish the same ssid with diferents vlans.
But i need to publish diferent SSID per AP.
Mohammad Aldehnee
Thanks for the answer!
Even i told the same with Link!! i guess you did not go through the link correctly!!
Surendra
Surendra BG
Finally i resolve the problem using Vlan Override feature clicking:
Wireless --> Access-Points --> Radios --> 802.11x -->Choose AP --> Click Configuration --> Choose Enable in Vlan Override
http://www.youtube.com/watch?v=N55EBOn2zZU
WOW!! Thats great to hear!!... n FYI.. in the newer WLC software versions.. WLAN Override is nothing but AP-Groups.. that is after 5.X and above its AP groups..
Surendra
Surendra BG
