Indoor AP 3702E and outdoor AP 1572EAC-M-K9
ibrahim_commu1
Dear Guys,
1- I just want to know is it possible to convert indoor access point AIR-CAP3702E-E-K9 to work as standalone instead of control based or this is not possible?
2- if I have 2 outdoor access point AIR-AP1572EAC-M-K9 and I want to connect them as point to point and distance between them 300m, is it possible to connect them with the specified distance or it will not supported?
Bob Bagheri
Yes you can convert the 3700 to autonomous via a controller or a manual process.
In regard to your 1500's your didtance for P2P depends on the antenna.  As long as the antenna is compatible with your AP the range depends on thr antennas rating.
Bob
Thanks Bob,
if I use the external antenna AIR-ANT5114P2M-N= for this outdoor access points, will it be ok? or not ?
Here is a link to the 1570 range calculator.
http://173.37.206.125/aspnet_client/system_web/2_0_50727/WNG_Coverage_Capacity_Calculator_V3.13/WNG_Coverage_Capacity_Calculator_V3.13.asp
300M isn't bad if the sites are line of sight without any obstructions.
-Scott
-Scott
