IOS Conversion on Lightweight Access points
Mikey John
Level 4
Level 4
Hi All,
I have a LAP-1131AG which I need to convert to an IOS based AP. Can you please tell me the procedure or tool which would help me with this?
Appreciate your help.
Mikey
Surendra BG
Hi Mikey,
Here is the document that has the step by step procedure.. In this document i have used 1141 AP, please make sure you cownload the 1131 AP image and follow the same.
https://supportforums.cisco.com/docs/DOC-14960
Lemme know if this answered your question
Surendra
Surendra BG
Hi Surendra,
Thanks for guiding me to the document. Let me give it a shot rightaway.
Cheers
Mikey
no problem!! lemme know if u face any issues..
Surendra.
Surendra BG
