is Cisco 9100 Series Access Point are compatible with WLC 2504 / 5508
please let me know is Cisco 9100 Series Access Point are compatible with WLC 2504 / 5508 / 5520.
Can Cisco 9100 Series Access Point work with WLC 2504 / 5508 / 5520 or not.
4 Accepted Solutions
AdamF1
No as 5508's do not support the code level needed.
8.9 was the first code to start supporting 9100 series AP's but not all of them. 5508's are EOL and only support up 8.5 I believe.
If you ever need to know which AP's are supported on your code version you can look at the release notes and then click on the link at the top of the page that has Supported Cisco Access points.
    - FYI : https://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
 M.
Leo Laohoo
No, they are not.
The APs require WLC that run 8.10.X.X and 2504/5508/WiSM-2 final firmware support is 8.5.X.X.
5 Replies 5
AdamF1
 M.
Leo Laohoo
No, they are not.
