Issue with Gui Aironet 2702i
tomnick
Hi, I bought a used AIR-CAP2702I-E-K9 with ap3g2-k9w7-xx.153-3.JPJ2 installed. I am trying to set up the network interface settings for a repeater but it only shows me a very short version of it and not the long one. What have I done wrong? Thanks for a little hint....
2 Accepted Solutions
Rich R
Yes stick to using the CLI to configure those autonomous APs.
There are a number of bugs in the GUI which will not be fixed so if it works great, if it doesn't use the CLI.
You could also try older versions of software if you insist on using the GUI and then upgrade once you have a working config.
marce1000
                   - Can you post a screenshot ?
 M.
Rich R
