Issues connecting Android 10 to Cisco ME
dovla091
Hi, I had one problem which I found bypass solution, but I would like to share with someone, as I don't want that someone is wasting time as I did troubleshooting the issue.
My case was that I have 15 APs AP1832i set to Cisco ME, so 1 acts as a call it a  "controller", while others are getting the instruction. I have set latest version of firmware for APs - 8.10.105.0
Now I have Nokia 7.1 running Android 10 December 2019 patch, and what I found out that after upgrading Android to version 10 and patching Cisco AP1832i from 8.5 to 8.10, android phone cannot connect anymore.
After 1 hour of troubleshooting I found a bypass. By enabling WPA3 (along with WPA2), android 10 started to connect again.
My guess is either Google completely ditched support for WPA2 (for some reason), in favor for WPA3 or there is some mismatch between Cisco 8.10.105.0 for ME and Google Android 10. By enabling WPA3, phone can successfully connect to our network.
I hope I helped someone, and saved him/her some time in dealing with tedious troubleshooting
Best regards
64 Replies 64
We had this issue with Android v12 release few days ago.
I confimred we fixed this issue by disabling the FAST TRANSITION feature in our WLANs properties (located in SECURITY/LAYER2 tabs).
We are using Wireless Cisco Catalyst 9800 and AP1840.
Thanks for this discussion thread.
I have similar Problem with Nokia and Huawei.
Wireless deployment is with 9800-40 and 9115ax - Amsterdam - 17.3.x.
My success workarround is by disabling FT future in WLAN and Device Analyrics.
Disable FT
Configuration > Tags&Profiles > WLAN > Open Problem SSID > Security - Fast Transition (Disabled)
Disable Device Analytics
Configuration > Tags&Profiles > WLAN > Open Problem SSID > Advanced > Advertise Support (Unchecked).
Good Luck !
MartinButlers
In my case enabling WPA3 on 1832i/1852e with ME 8.10.142.0 wasn't enough. I did also change in WLAN Settings/Advanced 802.11r to "enabled" from default "adaptive". Thanks for this post. It saved me lots of time.
Thank you for the solution,
it is a working and effective workaround
however, I don't know why this happened but I guess the suggestion you said about android 10 update is correct
ITTop
Android 10 uses pure WPA3
We solved the issue by creating a separate SSID and following this guide
https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/wpa3-dep-guide-og.html#WPA3EnterpriseGUIconfiguration
and it works, our users can choose wpa2/3 or Wpa3 only
