IW3702, 8.5.151.0 - FlexConnect mode - %DOT11-5-EXPECTED_RADIO_RESET
rudimocnik
Hello
I noticed a radio issue with IW3702 APs running version 8.5.140.0 and FC mode. Looking at the logs on the APs I noticed a bunch of radio reset codes similar to those below. I did some searching online and I found a bug with the same issue for a different model AP and mode described here CSCvn56211. So I upgraded APs to the suggested version 8.5.151.0 however, the issue still remains.
*Sep  1 10:05:43.651: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 42
*Sep  1 10:05:43.659: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 56
*Sep  1 10:05:43.659: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 21
*Sep  1 10:05:43.663: %LINK-6-UPDOWN: Interface Dot11Radio0, changed state to down
*Sep  1 10:05:43.671: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 42
*Sep  1 10:05:43.675: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 27
*Sep  1 10:05:43.675: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Sep  1 10:05:43.679: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to administratively down
*Sep  1 10:05:44.291: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 56
*Sep  1 10:05:44.291: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 21
*Sep  1 10:05:44.291: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio0 due to the reason code 10
*Sep  1 10:05:44.291: %DOT11-5-EXPECTED_RADIO_RESET: Restarting Radio interface Dot11Radio1 due to the reason code 10
Does anyone have a similar issue?
Rudi
7 Replies 7
patoberli
Might be a bug. If I read you correct, it happens to more than one AP, right?
If yes, then I suggest you open a TAC.
Yeah multiple APs. I opened TAC issue. Waiting.
Ok, please keep us updated here too, would be great to read the solution.
i've similar issue on 8.5.170.0 with CAP2702Es. did u get any help from TAC?
Did you get any resolution on this? I'm in the progress of migrating a bunch of 3702's running 8.5.151.0 from local to FlexConnect mode and have started noticing these errors popping up in the logs.
Is there a reason why you don't upgrade to the newer 8.5.x builds?
I also found this bug, which is not exactly the same, but might be close enough:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvn53435
That one is fixed in the 8.5.160.0 release, but there are also other radio bugs that were fixed in the newer builds.
