WLAN is not discoverable
Christian81
I hope someone can help me. I try to configure the AP AIR-AP1852E-E-K9 without a WLC.
Mobility Express is installed on the device. The hole WLAN only consits of this AP.
I configured the AP via the provisioning WLAN. After the configuration has been saved I see for a short time the
configured WLAN (before the restart of the AP). After the restart is finsihed, the configured WLAN is not available
and the LED is blinking red. The lldp of the switch where the AP is connected shows "bridge" as the capability.
This explains why the WLAN is not discoverable. Why is the AP in the bridge mode after the initial connfiguration
and how can I change it?
Thanks for your support!
Christian81
The problem is solved. You have to assign the AP (not the WLC) an IP address because there is no DHCP.
In the console you can check if the ap has an ip address (show ip inter brief). "wired0" must have an ip. With the command "capwap ap ip <ip address> <subnet> <gateway>" you can assign the ip.
18 Replies 18
Arshad Safrulla
Can you connect a console and post the complete output here.
Do you mean the output during the boot process?
Yes from power on.
Please click Helpful if this post helped you and Accept as Solution (drop down menu at top right of this reply) if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
Christian81
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2021.09.28 14:16:55 =~=~=~=~=~=~=~=~=~=~=~=
U-Boot 2012.07 (btldr release 38) (Oct 29 2019 - 06:39:45)
This product contains some software licensed under the
"GNU General Public License, version 2" provided with
ABSOLUTELY NO WARRANTY under the terms of
"GNU General Public License, version 2", available here:
http://www.gnu.org/licenses/old-licenses/gpl-2.0.html
DRAM: 1 GiB
NAND (ONFI): Detected MICRON MT29F2G08ABBEAH4 [256 MiB]
SF: Detected Macronix MX25U3235F [4 MiB]
MFG data loaded
Scanning shenv data blocks
Total valid parts=4
Active shenv part[1:1], write_counter=4
PCI0 Link Intialized
PCI1 Link Intialized
Net:
PHY ID = 0x4dd074, eth0 found AR8033 PHY
PHY ID = 0x4dd074, eth1 found AR8033 PHY
Valid I2C chip addresses: 51 52
AP 1832/1852 detected...
Power Type: 802.3at POE detected...
Signature returns 0
BL signing verification success, continue to run...
Auto boot mode, use bootipq directly
Hit ESC key to stop autoboot: 5 4 3 2 1 0
Specified BOOT: part2
Booting from part2
Read 1024 bytes from volume part2 to 45000000
Read 62568741 bytes from volume part2 to 45000000
Signature returns 0
Image signing verification success, continue to run...
Using machid 0x1260 from environment
Starting image ...
[01/01/1970 00:00:00.0000] CPU: ARMv7 Processor [512f04d0] revision 0 (ARMv7), cr=10c5387d
[01/01/1970 00:00:00.0000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[01/01/1970 00:00:00.0000] Machine: Cisco Systems 11ac Wave2 Wifi Access Point
[01/01/1970 00:00:00.0000] Memory policy: ECC disabled, Data cache writealloc
[01/01/1970 00:00:00.0000] Kernel command line: ubi.mtd=0 crashkernel=500M-:64M@1280M usbcore.authorized_default=0 console=ttyHSL1,9600n8 activepart=part2 activeboot=0 wdgtriggered=0
[01/01/1970 00:00:00.1600] CPU1: Booted secondary processor
[01/01/1970 00:00:00.2300]
[01/01/1970 00:00:00.2300] +++ hydra_ap_gpio_value =3
[01/01/1970 00:00:39.3379] ACPU PVS: 1
[01/01/1970 00:00:41.1473] buginf tty flushing thread started, ttyport=eec7ba90
[*01/01/1970 00:00:47.2654] buginf() enabled.
[*01/01/1970 00:00:47.2754] Made it into bootsh: Jul 29 2020 09:44:37 T-cbfc6f1f9918f53aa2f774f4ee9f9aefab116a16-gcbfc6f1f-aut
Welcome to Cisco.
Usage of this device is governed by Cisco's End User License Agreement,
available at:
http://www.cisco.com/c/en/us/td/docs/general/warranty/English/EU1KEN_.html.
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to
restrictions as set forth in subparagraph (c) of the Commercial
Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and
subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
"GNU Library General Public License, version 2" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Library
http://www.gnu.org/licenses/old-licenses/lgpl-2.0.html
"GNU Lesser General Public License, version 2.1" provided
with ABSOLUTELY NO WARRANTY under the terms of "GNU Lesser
General Public License, version 2.1", available here:
http://www.gnu.org/licenses/old-licenses/lgpl-2.1.html
"GNU General Public License, version 3" provided with
"GNU General Public License, Version 3", available here:
http://www.gnu.org/licenses/gpl.html.
"GNU Affero General Public License, version 3" provided
"GNU Affero General Public License, version 3", available here:
http://www.gnu.org/licenses/agpl-3.0.html.
[ OK ] Reached target Timers.
[ OK ] Reached target Cisco File Systems (Pre).
[ OK ] Created slice -.slice.
[ OK ] Listening on Delayed Shutdown Socket.
[ OK ] Reached target Sockets.
[ OK ] Created slice system.slice.
[ OK ] Reached target Slices.
[ OK ] Created slice system-serial\x2dgetty.slice.
Starting Cisco UBIFS reformat/mount...
[ OK ] Started Cisco UBIFS reformat/mount.
Starting Cisco early mount...
[ OK ] Started Cisco early mount.
[ OK ] Reached target Local File Systems (Pre).
Starting Cisco system time setup...
[*01/01/1970 00:00:53.0536] Last reload time: Sep 28 12:11:04 2021
[*09/28/2021 12:11:04.0000] Setting system time Tue Sep 28 12:11:04 UTC 2021
Starting Cisco fips check...
Starting Cisco platform file generation...
[*09/28/2021 12:11:04.3199] GCM-128 POST passed
[*09/28/2021 12:11:04.3199] GCM-256 POST passed
Starting Cisco seed generation...
[ OK ] Started Cisco system time setup.
[ OK ] Started Cisco fips check.
[ OK ] Started Cisco platform file generation.
[ OK ] Started Cisco seed generation.
[ OK ] Reached target Local File Systems.
Starting Cisco S10 boot service...
Starting Cisco pkg install service...
[ OK ] Started Cisco system time saving.
Starting Cisco system time saving...
[09/28/2021 12:11:04.0799] sysctl link missing during unregister: /net/ipv4/neigh//eth0
[09/28/2021 12:11:04.2899] sysctl link missing during unregister: /net/ipv4/neigh//eth1
[ OK ] Started Cisco S10 boot service.
Starting Cisco nss service...
Starting Cisco watchdog...
[*09/28/2021 12:11:05.7495] === 5G radio domain is 12, COPY 5G BDF files from ETSI_BDF folder ===
[*09/28/2021 12:11:05.7894] /etc/init.d/S10boot: Warning: deleting backup ap images to save storage...
[*09/28/2021 12:11:05.8094] 1
[*09/28/2021 12:11:06.0494] Active version: 8.10.130.0
[*09/28/2021 12:11:06.0594] Backup version: 0.0.0.0
[*09/28/2021 12:11:06.3093]
[*09/28/2021 12:11:06.3093] led pattern module start
[*09/28/2021 12:11:06.3493] AP1852I
[*09/28/2021 12:11:06.4692] nss_driver - Turbo Support 1
[*09/28/2021 12:11:06.4692] Supported Frequencies - 110Mhz 550Mhz 733Mhz
[*09/28/2021 12:11:06.5092] NSS firmware booted
[*09/28/2021 12:11:06.5392] NSS firmware booted
[*09/28/2021 12:11:07.0191] Current value of FACTORY_RESET=0
[*09/28/2021 12:11:07.0390] Last reload time: Sep 28 12:11:04 2021
[*09/28/2021 12:11:04.1899] device wired0 entered promiscuous mode
[*09/28/2021 12:11:04.3699] device wired1 entered promiscuous mode
[*09/28/2021 12:11:05.1696] Last reload reason : 0: unknown
Starting Cisco nolan service...
[ OK ] Started Cisco pkg install service.
[ OK ] Started Cisco nss service.
[ OK ] Started Cisco watchdog.
[ OK ] Started Cisco nolan service.
Starting Cisco Kclick...
Starting Cisco nolan USB service...
Starting Cisco S15platform...
[*09/28/2021 12:11:07.3090] stile module dp init successfully
[*09/28/2021 12:11:07.3090] NBAR Label:BLD_POLARIS_DEV_LATEST_20200414_053707 Module timestamp: Jul 29 2020 at 09:33:15 User: ttaichol
[ OK ] Started Cisco Kclick.
[ OK ] Started Cisco nolan USB service.
[ OK ] Started Cisco S15platform.
Starting Cisco certificate create service...
Starting Cisco ME service...
[*09/28/2021 12:11:08.0687] Loading sha2...
[*09/28/2021 12:11:08.0687] Dumpping sha1...
Starting Cisco syslog service...
Starting rsyslog client...
[*09/28/2021 12:11:08.3586] miibus get eee21400!
Starting Cisco S16platfomm...
[ OK ] Started Cisco syslog service.
[ OK ] Started rsyslog client.
[ OK ] Started Cisco S16platfomm.
[ OK ] Started Cisco ME service.
Starting Cisco synclogd...
[ OK ] Started Cisco synclogd.
[*09/28/2021 12:11:09.4783] pid 2896's current affinity mask: 3
[*09/28/2021 12:11:09.4783] pid 2896's new affinity mask: 1
[*09/28/2021 12:11:09.5283] Loading MIC cert and key
[*09/28/2021 12:11:09.5383] Dumpping sha2...
[ OK ] Started Cisco certificate create service.
Starting Cisco certtime service...
[ OK ] Started Cisco certtime service.
[ OK ] Reached target System Initialization.
[*09/28/2021 12:11:10.9078] Loading MIC cert and key
[ OK ] Reached target Paths.
[ OK ] Reached target Basic System.
Starting Cisco rtd service...
Starting Cisco klogd...
Starting Cisco printkd...
Starting gRPC server daemon...
Starting AP Trace daemon...
Starting Cisco led service...
Starting Fast CGI daemon...
[ OK ] Started NSS Firmware Monitor daemon.
Starting NSS Firmware Monitor daemon...
Starting WCPD process...
Starting OpenSSH server daemon...
[ OK ] Started Serial Getty on ttyS0.
Starting Serial Getty on ttyS0...
[ OK ] Reached target Login Prompts.
Starting Hostapd process...
Starting capwapd...
Starting Cisco kexec...
[ OK ] Started NTP_PROC daemon.
Starting NTP_PROC daemon...
Starting Cisco brain service...
[ OK ] Started System Monitor service.
Starting System Monitor service...
Starting Clean Air daemon...
[ OK ] Started Cisco led service.
[ OK ] Started Cisco kexec.
[ OK ] Started OpenSSH server daemon.
[ OK ] Started Cisco klogd.
[ OK ] Started Cisco printkd.
[ OK ] Started Cisco rtd service.
[ OK ] Started AP Trace daemon.
[ OK ] Started Fast CGI daemon.
[ OK ] Started Hostapd process.
[ OK ] Started Cisco brain service.
[*09/28/2021 12:11:14.1968] pid 3007's current affinity mask: 3
[*09/28/2021 12:11:14.1968] pid 3007's new affinity mask: 1
[*09/28/2021 12:11:15.3065] pid 3090's current affinity mask: 3
[*09/28/2021 12:11:15.3065] pid 3090's new affinity mask: 1
[*09/28/2021 12:11:16.2062] pid 3145's current affinity mask: 3
[*09/28/2021 12:11:16.2062] pid 3145's new affinity mask: 1
[*09/28/2021 12:11:16.4661] __mm_init_module
[*09/28/2021 12:11:16.5161]
[*09/28/2021 12:11:16.5161] __ol_ath_attach() Allocated scn c3d80480
[*09/28/2021 12:11:16.5361] ol_ath_attach interface_id 0
[*09/28/2021 12:11:16.5361] Chip id: 0x9, chip version: 0x1000000
[*09/28/2021 12:11:16.5361] Target Version is 1000000
[*09/28/2021 12:11:16.5361] Flash Download Address c0000
[*09/28/2021 12:11:16.5361] ol_transfer_bin_file: flash data file defined
[*09/28/2021 12:11:16.5361] Cal location [0]: 00000000
[*09/28/2021 12:11:16.5361] Wifi0 NAND FLASH Select OFFSET 0x1000
[*09/28/2021 12:11:16.5561] qc98xx_verify_checksum: flash checksum passed: 0x467d
[*09/28/2021 12:11:16.5561] ol_transfer_bin_file 3861: Download Flash data len 12064
[*09/28/2021 12:11:16.5761]
[*09/28/2021 12:11:16.5761] Board data initialized
[*09/28/2021 12:11:16.6161] ol_ath_download_firmware :First OTP download and Execute is good address:0xa000 return param 4660
[*09/28/2021 12:11:16.6161] ol_ath_download_firmware:##Board Id 8 , CHIP Id 1
[*09/28/2021 12:11:16.6161] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS260_negative_pwr_offset_2G_v2_008.bin
[*09/28/2021 12:11:16.6860]
[*09/28/2021 12:11:16.6860] [Flash] : Ignore Module param
[*09/28/2021 12:11:16.6860] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*09/28/2021 12:11:16.7160] ol_transfer_bin_file: Downloading firmware file: AR900B/hw.2/athwlan.bin
[*09/28/2021 12:11:17.2559]
[*09/28/2021 12:11:17.2559] Click sched monitor: schedulers = 1
[*09/28/2021 12:11:17.8157] HTC Rx: insufficient length, got:4 expected =8
[*09/28/2021 12:11:17.8157] Startup Mode-0 set
[*09/28/2021 12:11:17.8157] HTC Service:0x0300 ep:1 TX flow control disabled
[*09/28/2021 12:11:17.8257] HTC Service:0x0100 ep:2 TX flow control disabled
[*09/28/2021 12:11:17.8257] Firmware_Build_Number:70
[*09/28/2021 12:11:17.8257] num_rf_chain:0x00000004 ht_cap_info:0x0000185b vht_cap_info:0x339a79b2 vht_supp_mcs:0x0000ffaa
[*09/28/2021 12:11:17.8257] RES CFG Support wmi_service_bitmap 9778
[*09/28/2021 12:11:17.8257] Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 50 to TGT
[*09/28/2021 12:11:17.8257] ol_ath_service_ready_event: sw_cal_support_check_flag: 1
[*09/28/2021 12:11:17.8957] wmi_ready_event_rx: WMI UNIFIED READY event
[*09/28/2021 12:11:17.8957] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FRAG_DESC_BANK_CFG sent to FW for radio ID = 0
[*09/28/2021 12:11:17.8957] spectral_init_netlink 81 NULL SKB
[*09/28/2021 12:11:17.9057] ACS not enabled
[*09/28/2021 12:11:17.9057] ol_ath_thermal_mitigation_attach: --
[*09/28/2021 12:11:17.9057] __ol_ath_attach() Allocated scn ed440480
[*09/28/2021 12:11:17.9156] ol_ath_attach interface_id 1
[*09/28/2021 12:11:17.9156] Chip id: 0x9, chip version: 0x1000000
[*09/28/2021 12:11:17.9156] Target Version is 1000000
[*09/28/2021 12:11:17.9156] Flash Download Address c0000
[*09/28/2021 12:11:17.9156] ol_transfer_bin_file: flash data file defined
[*09/28/2021 12:11:17.9156] Cal location [1]: 00004000
[*09/28/2021 12:11:17.9156] wifi1 NAND FLASH Select OFFSET 0x5000
[*09/28/2021 12:11:17.9356] qc98xx_verify_checksum: flash checksum passed: 0x2697
[*09/28/2021 12:11:17.9356] ol_transfer_bin_file 3861: Download Flash data len 12064
[*09/28/2021 12:11:17.9556]
[*09/28/2021 12:11:17.9556] Board data initialized
[*09/28/2021 12:11:18.0056] ol_ath_download_firmware :First OTP download and Execute is good address:0x9c00 return param 4660
[*09/28/2021 12:11:18.0056] ol_ath_download_firmware:##Board Id 7 , CHIP Id 1
[*09/28/2021 12:11:18.0056] ol_transfer_bin_file: Board Data File download to address=0xc0000 file name=AR900B/hw.2/boardData_AR900B_CUS239_negative_pwr_offset_5G_v2_007.bin
[*09/28/2021 12:11:18.0756]
[*09/28/2021 12:11:18.0756] [Flash] : Ignore Module param
[*09/28/2021 12:11:18.0756] ol_ath_download_firmware : Second OTP download and Execute is good, param=0x0
[*09/28/2021 12:11:18.0956] ol_transfer_bin_file: Downloading firmware file: AR900B/hw.2/athwlan.bin
[*09/28/2021 12:11:18.8154] FWLOG: [71474] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0xdeb001, 0x94c, 0x94c, 0x0 )
[*09/28/2021 12:11:18.8154] FWLOG: [71474] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/28/2021 12:11:18.8154] FWLOG: [71474] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/28/2021 12:11:18.8154] FWLOG: [71474] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/28/2021 12:11:19.2052] HTC Rx: insufficient length, got:4 expected =8
[*09/28/2021 12:11:19.2052] Startup Mode-0 set
[*09/28/2021 12:11:19.2052] HTC Service:0x0300 ep:1 TX flow control disabled
[*09/28/2021 12:11:19.2052] HTC Service:0x0100 ep:2 TX flow control disabled
[*09/28/2021 12:11:19.2052] Firmware_Build_Number:70
[*09/28/2021 12:11:19.2052] num_rf_chain:0x00000004 ht_cap_info:0x0000185b vht_cap_info:0x339b79b2 vht_supp_mcs:0x0000ffaa
[*09/28/2021 12:11:19.2052] RES CFG Support wmi_service_bitmap 9778
[*09/28/2021 12:11:19.2052] Sending Ext resource cfg: HOST PLATFORM as 0 and fw_feature_bitmap as 50 to TGT
[*09/28/2021 12:11:19.2052] ol_ath_service_ready_event: sw_cal_support_check_flag: 1
[*09/28/2021 12:11:19.2752] wmi_ready_event_rx: WMI UNIFIED READY event
[*09/28/2021 12:11:19.2752] htt_h2t_frag_desc_bank_cfg_msg - HTT_H2T_MSG_TYPE_FRAG_DESC_BANK_CFG sent to FW for radio ID = 1
[*09/28/2021 12:11:19.2852] acfg_attach: Offload using existing sock ed9ca800
[*09/28/2021 12:11:19.2852] spectral_init_netlink 81 NULL SKB
[*09/28/2021 12:11:19.2852] ACS not enabled
[*09/28/2021 12:11:19.2952] ol_ath_thermal_mitigation_attach: --
[*09/28/2021 12:11:19.3452] pktlog_init: Initializing Pktlog for AR900B, pktlog_hdr_size = 16
User Access Verification
Username: [*09/28/2021 12:11:20.0250] ol_txrx_set_mesh_mode val 1
[*09/28/2021 12:11:20.2049] FWLOG: [72849] WAL_DBGID_TX_AC_BUFFER_SET ( 0x3, 0xdeb001, 0x94c, 0x94c, 0x0 )
[*09/28/2021 12:11:20.2049] FWLOG: [72849] WAL_DBGID_TX_AC_BUFFER_SET ( 0x12, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/28/2021 12:11:20.2049] FWLOG: [72849] WAL_DBGID_TX_AC_BUFFER_SET ( 0x45, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/28/2021 12:11:20.2049] FWLOG: [72849] WAL_DBGID_TX_AC_BUFFER_SET ( 0x67, 0x1e, 0x94c, 0x94c, 0x0 )
[*09/28/2021 12:11:20.2049] FWLOG: [72857] WAL_DBGID_PDEV_INFO_PRINT ( 0x3a, 0x10, 0x0, 0x10, 0x0 )
[*09/28/2021 12:11:20.3649] ol_txrx_set_mesh_mode val 1
[*09/28/2021 12:11:22.3843] wmi_dbg_cfg_send: mod[0]00000000 dbgcfg40000000 cfgvalid[0] 00000000 cfgvalid[1] 00000000
[*09/28/2021 12:11:22.3942] wmi_dbg_cfg_send: mod[0]00000000 dbgcfg40000000 cfgvalid[0] 00000000 cfgvalid[1] 00000000
[*09/28/2021 12:11:22.5042]
[*09/28/2021 12:11:22.5042] !!!!! {/opt/cisco/bin/capwap_brain} failed writing /click/vrrp_elector/preferred_ap_name len 0 data: ""
[*09/28/2021 12:11:22.9141] ip6_port srcr2, ip6local fe80::ca84:a1ff:feda:4548, ip6 ::, plen 0, gw6 ::, gw6_mac 00:00:00:00:00:00, mtu 1500, vid 0, mode6 2(slaac)
[*09/28/2021 12:11:23.4940]
[*09/28/2021 12:11:23.4940] phy_value=0: org="0x1000" phy_reg="0x1000"
[*09/28/2021 12:11:23.4940] device wired1 left promiscuous mode
[*09/28/2021 12:11:24.7236] pid 4093's current affinity mask: 3
[*09/28/2021 12:11:24.7236] pid 4093's new affinity mask: 1
[*09/28/2021 12:11:24.8735] device aptrace0 entered promiscuous mode
[*09/28/2021 12:11:24.8835] pid 4076's current affinity mask: 3
[*09/28/2021 12:11:24.8835] pid 4076's new affinity mask: 1
[*09/28/2021 12:11:24.8935] device to_container entered promiscuous mode
[*09/28/2021 12:11:24.9035] pid 4091's current affinity mask: 3
[*09/28/2021 12:11:24.9035] pid 4091's new affinity mask: 1
[*09/28/2021 12:11:27.1428] chpasswd: password for user changed
[*09/28/2021 12:11:27.8926] DOT11_TXP[0]:Domain configured: 1 class:E
[*09/28/2021 12:11:28.2625] DOT11_TXP[1]:Domain configured: 12 class:E
[*09/28/2021 12:11:30.3118] DOT11_DRV[1]: Init Radio1
[*09/28/2021 12:11:30.3418] DOT11_DRV[1]: set_channel Channel set to 36
[*09/28/2021 12:11:30.3718] DOT11_DRV[0]: Init Radio0
[*09/28/2021 12:11:30.4018] DOT11_DRV[0]: set_channel Channel set to 6
[*09/28/2021 12:11:31.2915] DOT11_CFG[0] Radio Mode is changed from Local to FlexConnect
[*09/28/2021 12:11:31.2915] DOT11_CFG[0]: Starting radio 0
[*09/28/2021 12:11:31.2915] DOT11_DRV[0]: Start Radio0 - Begin
[*09/28/2021 12:11:31.2915] DOT11_DRV[0]: Start Radio0 - End
[*09/28/2021 12:11:31.2915] DOT11_CFG[1] Radio Mode is changed from Local to FlexConnect
[*09/28/2021 12:11:31.2915] DOT11_CFG[1]: Starting radio 1
[*09/28/2021 12:11:31.2915] DOT11_DRV[1]: Start Radio1 - Begin
[*09/28/2021 12:11:31.3015] DOT11_DRV[1]: Start Radio1 - End
[*09/28/2021 12:11:31.5814] DOT11_DRV[0]: Stop Radio0 - Begin
[*09/28/2021 12:11:31.6814] DOT11_DRV[0]: Stop Radio0 - End
[*09/28/2021 12:11:31.6914] DOT11_DRV[0]: set_channel Channel set to 1
[*09/28/2021 12:11:31.6914] DOT11_DRV[0]: Start Radio0 - Begin
[*09/28/2021 12:11:31.6914] DOT11_DRV[0]: Start Radio0 - End
[*09/28/2021 12:11:31.7014] DOT11_DRV[0]: Channel set to 1, width 20
[*09/28/2021 12:11:31.7014] DOT11_DRV[0]: Stop Radio0 - Begin
[*09/28/2021 12:11:32.0913] DOT11_DRV[0]: Stop Radio0 - End
[*09/28/2021 12:11:32.0913] DOT11_DRV[0]: Channel set to 1, width 20
[*09/28/2021 12:11:32.1113] DOT11_DRV[1]: Stop Radio1 - Begin
[*09/28/2021 12:11:32.1113] DOT11_DRV[1]: Stop Radio1 - End
[*09/28/2021 12:11:32.1213] DOT11_DRV[1]: set_channel Channel set to 36
[*09/28/2021 12:11:32.1313] DOT11_DRV[1]: Start Radio1 - Begin
[*09/28/2021 12:11:32.1313] DOT11_DRV[1]: Start Radio1 - End
[*09/28/2021 12:11:32.1313] DOT11_DRV[1]: Stop Radio1 - Begin
[*09/28/2021 12:11:32.5311] DOT11_DRV[1]: Stop Radio1 - End
[*09/28/2021 12:11:32.5311] DOT11_DRV[1]: Start Radio1 - Begin
[*09/28/2021 12:11:32.5311] DOT11_DRV[1]: Start Radio1 - End
[*09/28/2021 12:11:32.5311] DOT11_DRV[1]: Channel set to 36, width 20
[*09/28/2021 12:11:32.5311] DOT11_DRV[1]: Stop Radio1 - Begin
[*09/28/2021 12:11:32.5411] DOT11_DRV[1]: Stop Radio1 - End
[*09/28/2021 12:11:32.5411] DOT11_DRV[1]: Channel set to 36, width 20
[*09/28/2021 12:11:32.5811] Socket Valid Element wcp/wcp_db Handler set_vlan_name_map Data Length 10
[*09/28/2021 12:11:32.6011] Failed to send msg to wcp/Radio2.set_radius_extended_config
[09/28/2021 12:12:05.4308] sysctl link missing during unregister: /net/ipv4/neigh//srcr3
[09/28/2021 12:12:05.5108] sysctl link missing during unregister: /net/ipv6/neigh//srcr3
[09/28/2021 12:12:05.6108] sysctl link missing during unregister: /net/ipv4/neigh//mgmt
[09/28/2021 12:12:05.7008] sysctl link missing during unregister: /net/ipv6/neigh//mgmt
[*09/28/2021 12:12:05.7907] chatter: tohost_virtual :: ToHost: d[09/28/2021 12:12:05.7907] sysctl link missing during unregister: /net/ipv4/neigh//virtual
[09/28/2021 12:12:05.9507] sysctl link missing during unregister: /net/ipv6/neigh//virtual
evice 'virtual' went down
[09/28/2021 12:12:06.0507] sysctl link missing during unregister: /net/ipv4/neigh//ha_port
[09/28/2021 12:12:06.1706] sysctl link missing during unregister: /net/ipv6/neigh//ha_port
[*09/28/2021 12:12:06.2706] chatter: tohost_vlan0 :: ToHost: dev[09/28/2021 12:12:06.2706] sysctl link missing during unregister: /net/ipv4/neigh//vlan0
[09/28/2021 12:12:06.4305] sysctl link missing during unregister: /net/ipv6/neigh//vlan0
ice 'vlan0' went down
[09/28/2021 12:12:06.5305] sysctl link missing during unregister: /net/ipv4/neigh//vlan1
[09/28/2021 12:12:06.6405] sysctl link missing during unregister: /net/ipv6/neigh//vlan1
[*09/28/2021 12:12:06.5305] chatter: tohost_vlan1 :: ToHost: dev[09/28/2021 12:12:06.7404] sysctl link missing during unregister: /net/ipv4/neigh//vlan2
[09/28/2021 12:12:06.8904] sysctl link missing during unregister: /net/ipv6/neigh//vlan2
ice 'vlan1' went down
[*09/28/2021 12:12:06.7404] chatter: toho[09/28/2021 12:12:07.0004] sysctl link missing during unregister: /net/ipv4/neigh//vlan3
[09/28/2021 12:12:07.1503] sysctl link missing during unregister: /net/ipv6/neigh//vlan3
st_vlan2 :: ToHost: device 'vlan2' went down
[*09/28/2021 12:12[09/28/2021 12:12:07.2503] sysctl link missing during unregister: /net/ipv4/neigh//vlan4
[09/28/2021 12:12:07.4002] sysctl link missing during unregister: /net/ipv6/neigh//vlan4
:06.9904] chatter: tohost_vlan3 :: ToHost: device 'vlan3' went d[09/28/2021 12:12:07.5002] sysctl link missing during unregister: /net/ipv4/neigh//vlan5
[09/28/2021 12:12:07.6502] sysctl link missing during unregister: /net/ipv6/neigh//vlan5
own
[*09/28/2021 12:12:07.2503] chatter: tohost_vlan4 :: ToHost[09/28/2021 12:12:07.7501] sysctl link missing during unregister: /net/ipv4/neigh//vlan6
[09/28/2021 12:12:07.9101] sysctl link missing during unregister: /net/ipv6/neigh//vlan6
: device 'vlan4' went down
[*09/28/2021 12:12:07.5002] chatter:[09/28/2021 12:12:08.0100] sysctl link missing during unregister: /net/ipv4/neigh//vlan7
[09/28/2021 12:12:08.1600] sysctl link missing during unregister: /net/ipv6/neigh//vlan7
tohost_vlan5 :: ToHost: device 'vlan5' went down
[*09/28/2021 [09/28/2021 12:12:08.2600] sysctl link missing during unregister: /net/ipv4/neigh//vlan8
[09/28/2021 12:12:08.4199] sysctl link missing during unregister: /net/ipv6/neigh//vlan8
12:12:07.7501] chatter: tohost_vlan6 :: ToHost: device 'vlan6' w[09/28/2021 12:12:08.5199] sysctl link missing during unregister: /net/ipv4/neigh//vlan9
[09/28/2021 12:12:08.6698] sysctl link missing during unregister: /net/ipv6/neigh//vlan9
ent down
[*09/28/2021 12:12:08.0100] chatter: tohost_vlan7 :: T[09/28/2021 12:12:08.7698] sysctl link missing during unregister: /net/ipv4/neigh//vlan10
[09/28/2021 12:12:08.9298] sysctl link missing during unregister: /net/ipv6/neigh//vlan10
oHost: device 'vlan7' went down
[*09/28/2021 12:12:08.2600] cha[09/28/2021 12:12:09.0297] sysctl link missing during unregister: /net/ipv4/neigh//vlan11
[09/28/2021 12:12:09.1797] sysctl link missing during unregister: /net/ipv6/neigh//vlan11
tter: tohost_vlan8 :: ToHost: device 'vlan8' went down
[*09/28/[09/28/2021 12:12:09.2796] sysctl link missing during unregister: /net/ipv4/neigh//vlan12
[09/28/2021 12:12:09.4396] sysctl link missing during unregister: /net/ipv6/neigh//vlan12
2021 12:12:08.5199] chatter: tohost_vlan9 :: ToHost: device 'vla[09/28/2021 12:12:09.5396] sysctl link missing during unregister: /net/ipv4/neigh//vlan13
[09/28/2021 12:12:09.6995] sysctl link missing during unregister: /net/ipv6/neigh//vlan13
n9' went down
[*09/28/2021 12:12:08.7698] chatter: tohost_vlan1[09/28/2021 12:12:09.7995] sysctl link missing during unregister: /net/ipv4/neigh//vlan14
[09/28/2021 12:12:09.9494] sysctl link missing during unregister: /net/ipv6/neigh//vlan14
0 :: ToHost: device 'vlan10' went down
[*09/28/2021 12:12:09.0297] c[09/28/2021 12:12:10.0794] sysctl link missing during unregister: /net/ipv4/neigh//vlan15
[09/28/2021 12:12:10.2094] sysctl link missing during unregister: /net/ipv6/neigh//vlan15
hatter: tohost_vlan11 :: ToHost: device 'vlan11' went down
[*09[09/28/2021 12:12:10.3293] sysctl link missing during unregister: /net/ipv4/neigh//vlan16
[09/28/2021 12:12:10.4693] sysctl link missing during unregister: /net/ipv6/neigh//vlan16
/28/2021 12:12:09.2796] chatter: tohost_vlan12 :: ToHost: device 'vlan12' went down
[*09/28/2021 12:12:09.5396] chatter: tohost_vlan13 :: ToHost: device 'vlan13' went down
[*09/28/2021 12:12:09.7995] chatter: tohost_vlan14 :: ToHost: device 'vlan14' went down
[*09/28/2021 12:12:10.0694] chatter: tohost_vlan15 :: ToHost: device 'vlan15' went down
[*09/28/2021 12:12:10.3293] chatter: tohost_vlan16 :: ToHost: device 'vlan16' went down
[*09/28/2021 12:12:10.5892]
[*09/28/2021 12:12:10.5892] !!!!! {watchdogd} Process switchdrvr gone for 60s
Starting the Switchdriver...
Starting Switchdriver...
Cryptographic library self-test....
Testing SHA1 Short Message 1
Testing SHA256 Short Message 1
Testing SHA384 Short Message 1
SHA1 POST PASSED
Testing HMAC SHA1 Short Message 1
Testing HMAC SHA2 Short Message 1
Testing HMAC SHA384 Short Message 1
passed!
XML config selected
Starting SSHD: ok
Starting Redis-Server: ok
Starting naconnector: ok
Starting nginx: Starting DB Services...
ok
Starting NA Connector...
Validating XML configuration
creating logs dir
Cisco is a trademark of Cisco Systems, Inc.
Software Copyright Cisco Systems, Inc. All rights reserved.
Cisco AireOS Version 8.10.130.0
Initializing OS Services: ok
Initializing Serial Services: ok
Initializing Network Services: ok
Starting Statistics Service: ok
Unable to open dx flag file
Starting ARP Services: ok
Starting Trap Manager: ok
Starting Data Externalization services: ok
Starting Network Interface Management Services: ok
Starting System Services: ok
Starting SNMP services: ok
Starting Fastpath Hardware Acceleration: Starting Switching Services: ok
Starting QoS Services: ok
Starting Policy Manager: ok
Starting Data Transport Link Layer: ok
Starting Access Control List Services: ok
Starting System Interfaces: ok
Starting Client Troubleshooting Service: ok
Starting Certificate Database: Initializing Curl Globally..
ok
Starting VPN Services: ok
Starting Management Frame Protection: ok
Starting DNS Services: ok
Starting Secure Tunnelling Services: ok
ok
Starting LWAPP: ok
Starting CAPWAP: ok
Starting LOCP: ok
Starting Security Services: ok
Starting OpenDNS Services: ok
Starting Authentication Engine: ok
Starting Mobility Management: ok
Starting Capwap Ping Component: ok
Starting AVC Services: ok
Starting AVC Flex Services: ok
Starting Virtual AP Services: ok
Starting AireWave Director: ok
Starting Network Time Services: open rrm: not able to ipv4 by pass rule ok
Starting Cisco Discovery Protocol: ok
Starting Broadcast Services: ok
Starting Logging Services: ok
Starting DHCP Server: ok
Starting IDS Signature Manager: ok
Starting RFID Tag Tracking: ok
Starting RF Profiles: ok
Starting Mesh Services: ok
Starting TSM: ok
Starting CIDS Services: ok
Starting DTLS server: enabled in CAPWAP
Starting CleanAir: ok
Starting WIPS: ok
Starting SSHPM LSC PROV LIST: ok
Starting RRC Services: ok
Starting Alarm Services: ok
Starting FMC HS: ok
Starting FLEXEXPRESS ConfigSync Task: ok
Starting Hotspot Services: ok
Starting HTTP Image Download Task: ok
Starting Tunnel Services New: ok
Starting mDNS Services: ok
Starting Management Services:
Web Server: CLI: Secure Web: Starting IPSec Profiles component: ok
ok
(Cisco Controller)
Enter User Name (or 'Recover-Config' this one-time only to reset configuration to factory defaults)
User:
Christian81
attached is the output.
can you login to WLC from GUI and check if Internal AP also got the IP or not ?
Also check if WLANs are enabled/broadcasted or not?
see the pic:
Dont forget to arte helpful posts
There is no WLC. I want to manage the AP via Mobility Express and this AP is the only one in the WLAN.
I do not see any issues, could you please login to the WLC and post output for  "show wlan summary"
There is no WLC. I want to manage the AP via Mobility Express and this AP is the only one in the WLAN. I want to build up a new WLAN with only one AP.
Yes this AP is working as both (WLC/AP). Just login to the management IP address of WLC and check!
Also paste the show wlan summary output as @Arshad Safrulla  asked.
I can't login to the management because I don't see the SSID. So I can't connect to the WLAN.
Here is the output:
(Cisco Controller) >show wlan summary
Number of WLANs.................................. 1
WLAN ID WLAN Profile Name / SSID                          Status       Interface Name
1             FBA8 / FBA8                                                Enabled    management
you dont know the management IP address of the WLC/AP ?
Connect your laptop in same VLAN/LAN and then access WLC.
I know the ip address, of course. I configured it (192.168.5.31) in the configuration wizard, but the address is not reachable. Event ping is not working. Laptop and AP are in the same VLAN. Ping from the switch to the AP is not working as well.
what is the switchport config where this AP is connected ?
