Laptop is not connecting with 2504 controller based 1131AG Access point
I have initially configured  2504 controller with necessary parameters. & we have LAP1131AG access Points.   we have connected 2 Nos. of access points in network.  we are getting Both AP connected with controller,
Whenver i am trying to connect with this wireless network though SSID( currently, open authentication),  laptop's not connecting with it. it shown error that " Windows was unable to connect to SSIDname "
Please help me to resolve this problem.
thanks
sandeep
umar bhatti
Hi Sandeep,
Are you using internal dhcp scope or external.
umar bhatti
Hi Sandeep,
Hi Umar,
i am using external windows based server.  i am getting both access points in controller with IP address from External DHCP server.  But, laptop is not registring with SSID.
thanks\
sandeep
If WLC is set for open authentication then make sure on your laptop in your wirless network properties is using no authetication it might be on laptop its set to wpa or wpa2 etc.
Leo Laohoo
Let me get this straight ... Your laptop cannot connect to the SSID when you are running OPEN authentication?
If this is the case, then it's not a "wireless" or a "network" issue.  The issue lies squarely with your laptop.
Try another client:  Another laptop, smartphone or tablet.  Anything.
