Laptops losing internet capabilities in wireless controller.
asmolens
Community Member
Has anyone seen an issue with the Cisco 5508 model wireless controller where it is randomly dropping clients IP addresses ( specifically Lenovo users and noone else )? They connect to the SSID surf the web then eventually get lose wireless, They are still connected to the SSID but lose internet and ipv4 address.
5 Replies 5
Arshad Safrulla
This symptom may be due to drivers. Upgrade the wireless NIC's to the latest drivers. Once done if the issue still persist, please post a debug client output from WLC for an impacted client.
David Ritter
Level 10
Level 10
very short DHCP lease time?
Leo Laohoo
This issue is only affecting Lenovo laptops?  Are all the laptops of the same model?  What is the exact model number of the wireless NIC?  What is the exact version of the firmware of the wireless NIC?
JPavonM
Which code release are you running? Does your APs work in Fleconnect mode?  Which AP model is affected (COS-AP)?
I've experienced similar issues in c9800 with COS-APs and at the end I was hitting CSCvw30043 that is fixed in 17.3.3.
My symptoms were that all locally forwarded clients (laptops) connected to some APs were not receiving DHCP Offer so losing the IP address, but centrally forwarded clients were working fine (BYOD and Guest devices). This happened every 20 days more or less, aand always to the same APs. Bouncing the radio interface did the trick if not updating the code.
As AP firmware is shared between c9800 and AireOS WLCs, check if this is something that maybe fixed with the latest code.
Moreover, I've experienced similar issues with IOS-APs but due to the fact that these APs are not receiving new code updates nor TAC is investigating the issues due to the previous fact, there is nothing we can do except swap them by COS-APs.
-Jesus
*** Please rate helpful responses ***
Rich R
A few years back we had a similar problem after IT team pushed a Windows firewall policy update which prevented the PC from doing a DHCP renew so that's another thing to consider.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
