Layer 3 discovery request not received on management interface
mseck0001
Hello Cisco Community members,
I tried to configure a controller and APs to join the WLC but got this error message on WLC statistics :Layer 3 discovery request not received on management interface.
The APs are on different subnets and have fixed IP addresses on their own subnet. In the controller, I configured a dynamic interface for each subnet. I also used physical port of controller for each dynamic interface.
In the switch connected to the controller and where APs are connected, I configured the port connected to each port of the controller as trunk and port connected to APs as access regarding the vlan of subnet.
Can you help please on the issue?
9 Replies 9
ERIK S
Are you using option 43 or how are you having the APs figure out what the WLC's IP is?
Hi Erik
Thanks for your reply. I am not using dhcp option 43. I just fixed AP's IP addresses and configured vlan on switch. The subnet of the management interface is different with AP's subnet. I configured a dynamic interface with a physical port on same subnet as APs
Rasika Nayanajith
For testing, would you be able to put one of those APs on the same vlan as WLC management subnet ? I would like to see whether AP register to WLC without any problem ?
Give more detail about WLC model, firmware version, AP model as well. ("show sysinfo" from wlc & "show version" from AP is good)
Rasika
CiscoWiFiGuy
Level 3
Level 3
i am also getting this "L3 discovery request not received on management vlan" while checking the not joined stats of access points.
so currently its a mix and match kind of scenario. Some access points have joined the wlc while other are showing this message.
wlc model is 5520 with 8.10.151 and ap model is 9120i. I saw they do have option 43 on dhcp server. So any idea what could be the issue.
thanks
are this issue solved or not ?
MHM
Not yet so please share your views as what could be the possible cause of this issue.
AP discover the WLC via L2 if both in same subnet
AP discover the WLC via DHCP op if both in different subnet
so let start are AP get IP from DHCP ?
MHM
Yes Ap's and WLC are in different subnets and it seems Aps are getting ip as i can see them while doing show logging. seems something related to timers possibly? do i have to adjust the retransmit timers?
Posting some of the output of show logging command:
*spamApTask5: Jan 04 17:41:38.527: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:8271 Did not receive heartbeat reply; AP: 6c:41:0e:1e:fd:60
*spamApTask2: Jan 04 17:41:38.324: %LWAPP-3-AP_DEL: spam_lrad.c:6088 6c:41:0e:44:f0:e0: Entry deleted for AP: 10.10.6.92 (5260) reason : Echo Timer Expiry.
*spamApTask0: Jan 04 17:41:38.323: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7521 6c:41:0e:44:f0:e0: DTLS connection closed forAP 10:10:6:92 (5260), Controller: 10:10:3:242 :41:35.671: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7521 6c:41:0e:1f:7a:20: DTLS connection closed forAP 10:10:6:86 (5274), Controller: 10:10:3:242 (5246) Echo Timer Expiry
*spamApTask0: Jan 04 17:41:35.671: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:8271 Did not receive heartbeat reply; AP: 6c:41:0e:1f:7a:20
*spamApTask4: Jan 04 17:41:35.060: %LWAPP-3-AP_DEL: spam_lrad.c:6088 6c:41:0e:1f:59:80: Entry deleted for AP: 10.10.6.98 (5260) reason : Echo Timer Expiry.
*spamApTask6: Jan 04 17:41:35.059: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7521 6c:41:0e:1f:59:80: DTLS connection closed forAP 10:10:6:98 (5260), Controller: 10:10:3:242 (5246) Echo Timer Expiry
*spamApTask6: Jan 04 17:41:35.059: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:8271 Did not receive heartbeat reply; AP: 6c:41:0e:1f:59:80
*spamApTask4: Jan 04 17:41:34.857: %LWAPP-3-AP_DEL: spam_lrad.c:6088 6c:41:0e:1d:9d:20: Entry deleted for AP: 10.10.6.88 (5270) reason : Echo Timer Expiry.
*spamApTask7: Jan 04 17:41:34.856: %LWAPP-3-AP_DEL: spam_lrad.c:6088 6c:41:0e:44:15:e0: Entry deleted for AP: 10.10.6.100 (5273) reason : Echo Timer Expiry.
*spamApTask6: Jan 04 17:41:34.856: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7521 6c:41:0e:1d:9d:20: DTLS connection closed forAP 10:10:6:88 (5270), Controller: 10:10:3:242 (5246) Echo Timer Expiry
*spamApTask5: Jan 04 17:41:34.855: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7521 6c:41:0e:44:15:e0: DTLS connection closed forAP 10:10:6:100 (5273), Controller: 10:10:3:242 (5246) Echo Timer Expiry
*spamApTask6: Jan 04 17:41:34.855: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:8271 Did not receive heartbeat reply; AP: 6c:41:0e:1d:9d:20
*spamApTask5: Jan 04 17:41:34.855: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:8271 Did not receive heartbeat reply; AP: 6c:41:0e:44:15:e0
*spamApTask1: Jan 04 17:41:33.428: %LWAPP-3-AP_DEL: spam_lrad.c:6088 6c:41:0e:45:17:60: Entry deleted for AP: 10.10.6.99 (5264) reason : Echo Timer Expiry.
*spamApTask3: Jan 04 17:41:33.427: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7521 6c:41:0e:45:17:60: DTLS connection closed forAP 10:10:6:99 (5264), Controller: 10:10:3:242 (5246) Echo Timer Expiry
*spamApTask3: Jan 04 17:41:33.427: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:8271 Did not receive heartbeat reply; AP: 6c:41:0e:45:17:60
*spamApTask3: Jan 04 17:41:32.408: %LWAPP-3-AP_DEL: spam_lrad.c:6088 6c:41:0e:1f:60:a0: Entry deleted for AP: 10.10.6.91 (5250) reason : Echo Timer Expiry.
*spamApTask5: Jan 04 17:41:32.407: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7521 6c:41:0e:1f:60:a0: DTLS connection closed forAP 10:10:6:91 (5250), Controller: 10:10:3:242 (5246) Echo Timer Expiry
*spamApTask5: Jan 04 17:41:32.407: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:8271 Did not receive heartbeat reply; AP: 6c:41:0e:1f:60:a0
*spamApTask1: Jan 04 17:41:31.796: %LWAPP-3-AP_DEL: spam_lrad.c:6088 6c:41:0e:45:19:60: Entry deleted for AP: 10.10.6.101 (5254) reason : Echo Timer Expiry.
*spamApTask3: Jan 04 17:41:31.795: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7521 6c:41:0e:45:19:60: DTLS connection closed forAP 10:10:6:101 (5254), Controller: 10:10:3:242 (5246) Echo Timer Expiry
*spamApTask3: Jan 04 17:41:31.795: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:8271 Did not receive heartbeat reply; AP: 6c:41:0e:45:19:60
*spamApTask6: Jan 04 17:41:31.184: %LWAPP-3-AP_DEL: spam_lrad.c:6088 6c:41:0e:1e:2b:00: Entry deleted for AP: 10.10.6.89 (5261) reason : Echo Timer Expiry.
*spamApTask6: Jan 04 17:41:31.183: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7521 6c:41:0e:1e:2b:00: DTLS connection closed forAP 10:10:6:89 (5261), Controller: 10:10:3:242 (5246) Echo Timer Expiry
*spamApTask6: Jan 04 17:41:31.183: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:8271 Did not receive heartbeat reply; AP: 6c:41:0e:1e:2b:00
*spamApTask5: Jan 04 17:41:30.777: %LWAPP-3-AP_DEL: spam_lrad.c:6088 6c:41:0e:1f:7e:00: Entry deleted for AP: 10.10.6.87 (5256) reason : Echo Timer Expiry.
*spamApTask4: Jan 04 17:41:30.776: %LWAPP-3-AP_DEL: spam_lrad.c:6088 6c:41:0e:45:1d:40: Entry deleted for AP: 10.10.6.96 (5262) reason : Echo Timer Expiry.
*spamApTask6: Jan 04 17:41:30.775: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7521 6c:41:0e:45:1d:40: DTLS connection closed forAP 10:10:6:96 (5262), Controller: 10:10:3:242 (5246) Echo Timer Expiry
*spamApTask7: Jan 04 17:41:30.775: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7521 6c:41:0e:1f:7e:00: DTLS connection closed forAP 10:10:6:87 (5256), Controller: 10:10:3:242 (5246) Echo Timer Expiry
*spamApTask6: Jan 04 17:41:30.775: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:8271 Did not receive heartbeat reply; AP: 6c:41:0e:45:1d:40
*spamApTask7: Jan 04 17:41:30.775: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:8271 Did not receive heartbeat reply; AP: 6c:41:0e:1f:7e:00
*spamApTask2: Jan 04 17:41:29.140: %LWAPP-3-AP_DEL: spam_lrad.c:6088 6c:41:0e:44:7e:20: Entry deleted for AP: 10.10.6.97 (5257) reason : Echo Timer Expiry.
*spamApTask2: Jan 04 17:41:29.139: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7521 6c:41:0e:44:7e:20: DTLS connection closed forAP 10:10:6:97 (5257), Controller: 10:10:3:242 (5246) Echo Timer Expiry
*spamApTask2: Jan 04 17:41:29.139: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:8271 Did not receive heartbeat reply; AP: 6c:41:0e:44:7e:20
*spamApTask0: Jan 04 17:41:27.712: %LWAPP-3-AP_DEL: spam_lrad.c:6088 6c:41:0e:45:27:60: Entry deleted for AP: 10.10.6.75 (5257) reason : Echo Timer Expiry.
*spamApTask4: Jan 04 17:41:27.711: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7521 6c:41:0e:45:27:60: DTLS connection closed forAP 10:10:6:75 (5257), Controller: 10:10:3:242 (5246) Echo Timer Expiry
*spamApTask4: Jan 04 17:41:27.711: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:8271 Did not receive heartbeat reply; AP: 6c:41:0e:45:27:60
*spamApTask0: Jan 04 17:41:26.284: %LWAPP-3-AP_DEL: spam_lrad.c:6088 6c:41:0e:44:7d:c0: Entry deleted for AP: 10.10.6.76 (5270) reason : AP Message Timeout.
*spamApTask2: Jan 04 17:41:26.283: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7521 6c:41:0e:44:7d:c0: DTLS connection closed forAP 10:10:6:76 (5270), Controller: 10:10:3:242 (5246) AP Message Timeout
*spamApTask2: Jan 04 17:41:26.283: %CAPWAP-3-MAX_RETRANSMISSIONS_REACHED: capwap_ac_sm.c:8073 Max retransmissions reached on AP(6c:41:0e:44:7d:c0),message (CAPWAP_CONFIGURATION_UPDATE_REQUEST
),number of pending messages(1)
*spamApTask2: Jan 04 17:41:23.628: %LWAPP-3-AP_DEL: spam_lrad.c:6088 6c:41:0e:1f:79:60: Entry deleted for AP: 10.10.6.78 (5254) reason : Echo Timer Expiry.
*spamApTask4: Jan 04 17:41:23.627: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7521 6c:41:0e:1f:79:60: DTLS connection closed forAP 10:10:6:78 (5254), Controller: 10:10:3:242 (5246) Echo Timer Expiry
*spamApTask4: Jan 04 17:41:23.627: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:8271 Did not receive heartbeat reply; AP: 6c:41:0e:1f:79:60
*spamApTask7: Jan 04 17:41:18.324: %LWAPP-3-AP_DEL: spam_lrad.c:6088 6c:41:0e:45:02:00: Entry deleted for AP: 10.10.6.93 (5248) reason : AP Message Timeout.
*spamApTask5: Jan 04 17:41:18.323: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7521 6c:41:0e:45:02:00: DTLS connection closed forAP 10:10:6:93 (5248), Controller: 10:10:3:242 (5246) AP Message Timeout
*spamApTask5: Jan 04 17:41:18.323: %CAPWAP-3-MAX_RETRANSMISSIONS_REACHED: capwap_ac_sm.c:8073 Max retransmissions reached on AP(6c:41:0e:45:02:00),message (CAPWAP_CONFIGURATION_UPDATE_REQUEST
*spamApTask0: Jan 04 17:41:13.220: %LWAPP-3-AP_DEL: spam_lrad.c:6088 6c:41:0e:1f:6a:00: Entry deleted for AP: 10.10.6.190 (5268) reason : Echo Timer Expiry.
*spamApTask2: Jan 04 17:41:13.219: %CAPWAP-3-DTLS_CLOSED_ERR: capwap_ac_sm.c:7521 6c:41:0e:1f:6a:00: DTLS connection closed forAP 10:10:6:190 (5268), Controller: 10:10:3:242 (5246) Echo Timer Expiry
*spamApTask2: Jan 04 17:41:13.219: %CAPWAP-3-ECHO_ERR: capwap_ac_sm.c:8271 Did not receive heartbeat reply; AP: 6c:41:0e:1f:6a:00
Could you please share your views based on shared logs in earlier message?.
