load balancing traffic between AP 2802-series and LAN switch
Andrey128
I've just established etherchannel between 2802 AP and C2960S switch.
Which of such supported load-balancing modes can allow traffic balancing between two LAN ports connecting access point:
(config)# port-channel load-balance ?
dst-ip Dst IP Addr
dst-mac Dst Mac Addr
src-dst-ip Src XOR Dst IP Addr
src-dst-mac Src XOR Dst Mac Addr
src-ip Src IP Addr
src-mac Src Mac Addr
balaji.bandi
Suggested as per cisco standard : ( again depends on requirement - you can change and test)
port-channel load-balance src-dst-port
https://www.cisco.com/c/en/us/support/docs/wireless/aironet-3800-series-access-points/200898-Link-aggregation-on-1800-2800-3800-AP.html
BB
patoberli
Don't do it. The AP anyway can't reach speeds > 1 Gbps on wireless on normal circumstances, so you will not win anything by using load-balancing. Unless you can really use 2x a 160 MHz channel and you have 4 stream clients that are 160 MHz capable. Then it might be theoretically possible for it to reach > 1 Gbps peaks.
You will actually loose a switch port and have a way more complicated configuration.
