Local EAP - Using PEAP
NC16390371
Frequent Visitor
Frequent Visitor
I have a question with regards to Local EAP. After you have created your Local EAP profile and applied it to an SSID a client with the appropriate certificate and local net user ID is authenticated. Once the user is authenticated does the client re-authenticate as he roams ? Are his credentials cached on the controller ?
dziminski
Level 2
Level 2
If the client roams across access points on the same controller, I don't think the client will have to re-authenticate as long as your client supports CCXv2 which supports CCKM (Cisco Centralized Key Management) for LEAP authentication.
http://www.cisco.com/web/partners/pr46/pr147/program_additional_information_new_release_features.html
You can use this command on the controller to see the pairwise-master key cache.
show pmk-cache all
