LWAPP accesspoit did not recieve config response from controller
FRANK SCHADE
I want to install a new delivered AP.
He even finds the controller but then I see on the AP:
%LWAPP-3-CLIENTERRORLOG: Config Request Timer: did not recieve config response (
controller - P1_C2106-1)
%SYS-5-RELOAD: Reload requested by LWAPP CLIENT. Reload Reason: DID NOT GET CONF
IG RESPONSE.
So it will reload for ever???
17 Replies 17
tomdamen18
Look @ debug information. i had the same problem. mine was fixd with al differnce in the county code.. debug whas telling me AP is on SA en mij wlan controler @ NL. so change it to SA en then youre ap's will join. then change it to youre county code.
Hi Tom, thanks! I cannot seem to locate the CLI command to set the country setting inside the AP (already in lwapp mode). Do you have a quick CLI reference? thanks
The AP gives output on booting someware in the middel. something like County=NL. change the County code in jou https:\\lwap adres\ select NL. let youre AP's boot all up then change it to jou county
edit you need to have console in the ap!
