Master controller mode in 9800 WLC ?
Is there a "master controller" functionality in the 9800's ?
I cant seem to find it anywhere, UI or config guides.
Is there another way of accomplishing "master controller" ?
Put one WLC in a MB group(name) by itself and only use that in discovery ?
(It properly would work, but ..... )
2 Accepted Solutions
Scott Fella
On the 9800’s there is no “master controller” equivalent setting. You either have to use option 43 or dns discovery and or just set the tag that defines the primary and secondary with fallback enabled. Here is a link to a guide:
https://www.cisco.com/c/dam/en/us/td/docs/wireless/controller/9800/17-4/deployment-guide/c9800-n-plus-1-high-availability-wp.pdf#page6
-Scott
Sure there is:
conf t
wireless priming-controller
end
--Sam
7 Replies 7
p.willemsen
Hi.
There is a master Controller connect to DNA Center.
Scott Fella
-Scott
Ill accept this as a solution.
But in 17.3.x the wording is "Backup Primary Controller" not just "Primary Controller".
Sure there is:
conf t
end
--Sam
This feature is enabled form release 17.4.xx
Sdiana
Hi Sam,
I have a 9800 WLC with IOS Version 16.12.5 and it doesn't recognized this command. Which version have you tried on this command?
LUCA_ITALY
Frequent Visitor
Frequent Visitor
WLC 9800 always annonce itself as "Master" this is an expected behavior:
https://quickview.cloudapps.cisco.com/quickview/bug/CSCvt22075
New APs will always prefere 9800 controller
