Missing Interface on C9800-CL
ivickery
I have deployed a C9800-CL on VMware, inside ESX I can see three interfaces..
But on the Controller there is only two.
Does anyone have any idea what has happened to the missing interface?
Ian
Jegan Rajappa
Level 3
Level 3
I guess you enabled HA SSO, once you enable it, Gi3 will disappear, disabling the redundancy and rebooting the controller brings Gi3 port again.
Scott Fella
You should post a screen shot.  Anyways, depending on what you want to implement, you might only require 1 interface.  Two if you are doing SSO and three if you have an OOB network for management that is separate from the wireless management.
G1 - OOB
G2 - Wireless management
G3 - RP for SSO
-Scott
gbarhams
Frequent Visitor
Frequent Visitor
WLC# clear chassis redundancy
then reload.
