Mobility Express Issues after Upgrade
AhmadZ
Level 4
Level 4
Dear All,
I've upgraded my Cisco AP1815i (from version 8.5.182 to 8.10.183) which is a mobility express and capwap at the same time. After upgrade, capwap remains unchanged while no access to mobility express, it seems like the IP of the mobility express has changed also.
I checked that the AP Image type is mobility express, but how can I change the mobility express IP? I couldn't find any command for such while logged in as SSH,
Thanks!
5 Replies 5
Denniz
Level 3
Level 3
Use a console cable (or ssh into it with the current ip) and use the commands;
en
capwap ap ip [ip-address] [netmask] [default router]
This changes the IP of the capwap, not the mobility express
You are right, I misread the question, thanks for pointing that out!
Mark Elsen
 - IP address should not change with upgrades  , perhaps someone forgot to save the config , perhaps it is advisable to reset the AP and configure the mobility express setup again (including IP)
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Rich R
If it's the same as AireOS WLC (ME is based on that) then try:
config interface address management <IP> <mask> <gateway>
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
