Mobility Express wired0: started and stopped and wired0 emac2: link up
amalitol81
Guys,
I just upload the Mobility Express image to my Cisco WAP 2802i, After complete the Wizard  I can't connect the WAP, not even by Wifi or wired. Notice that I have not configured DHCP Server due to I pretend to use the WAP in a Standalone mode as Local Bridge. The WAP also does not respond a ping. The WAP SO is AireOS 8.5.140.0 version.
The WAP is connected to an ACCESS PORT, 1000 Gbps port speed.
Does any body knows what could be cause ?
Thank you,
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Build Info....................................... Engineering Special
Product Version.................................. 8.5.140.0
System Name...................................... drair01
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.2370
IP Address....................................... 10.20.200.5
Last Reset....................................... 1: reload command
System Up Time................................... 0 days 0 hrs 14 mins 6 secs
System Timezone Location......................... (GMT -5:00) Eastern Time (US and Canada)
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
Configured Country............................... US - United States
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
--More-- or (q)uit
Number of WLANs.................................. 1
Number of Active Clients......................... 0
OUI Classification Failure Count................. 0
Memory Current Usage............................. 55
Memory Average Usage............................. 62
CPU Current Usage................................ 1
CPU Average Usage................................ 2
Flash Type....................................... Compact Flash Card
Flash Size....................................... 1073741824
Burned-in MAC Address............................ 70:70:8B:D0:03:40
Maximum number of APs supported.................. 100
System Nas-Id....................................
WLC MIC Certificate Types........................ SHA1/SHA2
(Cisco Controller) > show wlan summary
WLAN ID WLAN Profile Name / SSID Status Interface Name
1 ccoc / ccoc Enabled management
(Cisco Controller) >show interface summary
Number of Interfaces.......................... 2
Interface Name Port Vlan Id IP Address Type Ap Mgr Guest
management 1 untagged 10.20.200.5 Static Yes No
virtual N/A N/A 192.0.2.1 Static No No
 #### These are the console logs in real time
(Cisco Controller) >[05/02/2019 14:03:55.3100] wired0: stopped
[05/02/2019 14:03:57.3900] wired0 emac 2: link up
[05/02/2019 14:03:57.4400] wired0: link up
[05/02/2019 14:03:57.4800] wired0: started
[05/02/2019 14:04:12.6500] wired0: stopped
[05/02/2019 14:04:14.7400] wired0 emac 2: link up
[05/02/2019 14:04:14.7900] wired0: link up
[05/02/2019 14:04:14.8400] wired0: started
[05/02/2019 14:04:30.0400] wired0: stopped
[05/02/2019 14:04:32.1000] wired0 emac 2: link up
[05/02/2019 14:04:32.1600] wired0: link up
[05/02/2019 14:04:32.2000] wired0: started
[05/02/2019 14:04:47.4000] wired0: stopped
[05/02/2019 14:04:49.4800] wired0 emac 2: link up
[05/02/2019 14:04:49.5300] wired0: link up
[05/02/2019 14:04:49.5700] wired0: started
[05/02/2019 14:05:04.7600] wired0: stopped
[05/02/2019 14:05:06.8300] wired0 emac 2: link up
[05/02/2019 14:05:06.8800] wired0: link up
[05/02/2019 14:05:06.9300] wired0: started
[05/02/2019 14:05:22.1200] wired0: stopped
[05/02/2019 14:05:24.1900] wired0 emac 2: link up
[05/02/2019 14:05:24.2500] wired0: link up
[05/02/2019 14:05:24.2900] wired0: started
[05/02/2019 14:05:39.4900] wired0: stopped
[05/02/2019 14:05:41.5600] wired0 emac 2: link up
[05/02/2019 14:05:41.6200] wired0: link up
[05/02/2019 14:05:41.6600] wired0: started
[05/02/2019 14:05:56.8500] wired0: stopped
[05/02/2019 14:05:58.9300] wired0 emac 2: link up
[05/02/2019 14:05:58.9800] wired0: link up
[05/02/2019 14:05:59.0300] wired0: started
[05/02/2019 14:06:14.2100] wired0: stopped
[05/02/2019 14:06:16.2900] wired0 emac 2: link up
[05/02/2019 14:06:16.3500] wired0: link up
[05/02/2019 14:06:16.3900] wired0: started
[05/02/2019 14:06:31.5800] wired0: stopped
[05/02/2019 14:06:33.6500] wired0 emac 2: link up
[05/02/2019 14:06:33.7100] wired0: link up
[05/02/2019 14:06:33.7500] wired0: started
[05/02/2019 14:06:48.9400] wired0: stopped
[05/02/2019 14:06:51.0200] wired0 emac 2: link up
[05/02/2019 14:06:51.0700] wired0: link up
[05/02/2019 14:06:51.1200] wired0: started
[05/02/2019 14:07:06.3000] wired0: stopped
[05/02/2019 14:07:08.3800] wired0 emac 2: link up
[05/02/2019 14:07:08.4300] wired0: link up
[05/02/2019 14:07:08.4800] wired0: started
[05/02/2019 14:07:23.6700] wired0: stopped
[05/02/2019 14:07:25.7400] wired0 emac 2: link up
[05/02/2019 14:07:25.7900] wired0: link up
[05/02/2019 14:07:25.8400] wired0: started
[05/02/2019 14:07:41.0300] wired0: stopped
[05/02/2019 14:07:43.1000] wired0 emac 2: link up
[05/02/2019 14:07:43.1500] wired0: link up
[05/02/2019 14:07:43.2000] wired0: started
[05/02/2019 14:07:58.4000] wired0: stopped
[05/02/2019 14:08:00.4600] wired0 emac 2: link up
[05/02/2019 14:08:00.5200] wired0: link up
[05/02/2019 14:08:00.5600] wired0: started
[05/02/2019 14:08:15.7600] wired0: stopped
[05/02/2019 14:08:17.8300] wired0 emac 2: link up
[05/02/2019 14:08:17.8800] wired0: link up
[05/02/2019 14:08:17.9300] wired0: started
[05/02/2019 14:08:33.1200] wired0: stopped
[05/02/2019 14:08:35.1900] wired0 emac 2: link up
[05/02/2019 14:08:35.2400] wired0: link up
[05/02/2019 14:08:35.2900] wired0: started
Guys,
I got it !!! Here is the thing.
I want to have the DHCP externally just for "Wireless Users".
I also want to provide statics IPs to the WLC and the WAP attached.
When you do NOT configure an "INTERNAL DHCP Server" in the WLC first configuration wizard, it seems that the WAP attached to the WLC in Mobility Express mode do not know where to join, so this should be done manually. I did the following in order to allow my Mobility Express WLC and WAP work together.
Step 1: I switch from the WLC CLI to the WAP CLI
(Cisco Controller) > apciscoshell
AP7070.8BD0.0342> enable
AP7070.8BD0.0342#
AP7070.8BD0.0342# capwap ap hostname air01
air01# capwap ap ip 10.20.200.6 255.255.255.0 10.20.200.100 10.20.202.1 10.20.202.2 mydomain.local
air01# capwap ap primary-base wlc1 10.20.200.5
Guys after these commands I switched back to the WLC CLI and everything started to work.
air01# logout
So my conclusion is that if you don't want to use the Internal DHCP Server on the WLC Mobility Express Mode, and you want to use the WAP attached as LOCAL BRIDGE MODE for users accessing the Wireless network, you have to manually integrate the attached WAP and the WLC.
amalitol81
I also want to add that the WAP converted into a WLC has the LED state ALTERNATING BETWEEN GREEN AND RED, which means "Discovery/join process in progress".
Does anybody have an idea what is happening here ?
thank you,
amalitol81
thank you,
Two possibilities that I could think of.
1. You waited around 10 minutes for it to complete booting?
2. You are providing it with PoE+ power?
Can you show the output of a "show interfaces"?
Guys,
AP7070.8BD0.0342#
air01# logout
