ā03-04-2013 12:08 AM - edited ā07-03-2021 11:39 PM
We have sucessfully installed MSE-VA-7-4-100-0.ova file in our Lab, and after installation we can't open https session with MSE.
When we type <https://mymseipaddress> we are getting these message:
No service matched or handled this request.
Known services are:
http://my server:8880/hs/
http://my server:8880/mdp/
http://my server:8880/admin/
http://my server:8880/wips/
http://my server:8880/location/
http://my server:8880/subscription/
http://my server:8880/aaa/
http://127.0.0.1:8180/localadmin/
https://127.0.0.1:8443/localadmin/
https://my server:8843/mdp/
https://my server:8843/wips/
https://my server:8843/hs/
https://my server:8843/admin/
https://my server:8843/location/
https://my server:8843/subscription/
https://my server:8843/aaa/
We are able to import MSE to Cisco Prime Infrastructure 1.3 and we have communication with WLC. We have tried proposed solution explained in link below:
https://supportforums.cisco.com/message/3656441#3656441
but we are are unable to import server certificate becouse our certificate vallidation is falling. We don't know how we should append private key to the signed certificate in order to get our MSE web services up and running.
Any help in solving this problem would be much appreciated.
Jelena
ā03-04-2013 12:33 AM
From MSE
getserverinfo
ā03-04-2013 12:42 AM
Here is the output from getserverinfo:
[root@MDS-MSE-LAB ~]# getserverinfo
Health Monitor is running
Starting MSE Platform, Waiting to check the status.
MSE services are up, getting the status
Server Config
Product name: Cisco Mobility Service Engine
Version: 7.4.100.0
Health Monitor Ip Address: 1.1.1.1
High Availability Role: 1
Hw Version: V01
Hw Product Identifier: AIR-MSE-VA-K9
Hw Serial Number: MDS-MSE-LAB.mds.rs_3287d770-825b-11e2-8bd8-00505692612a
Use HTTP: false
Legacy HTTPS: false
Legacy Port: 8001
Log Modules: -1
Log Level: INFO
Days to keep events: 2
Session timeout in mins: 30
DB backup in days: 2
Services
Service Name: Context Aware Service
Service Version: 7.4.0.38
Admin Status: Enabled
Operation Status: Up
Service Name: WIPS
Service Version: 1.0.4041.0
Admin Status: Disabled
Operation Status: Down
Service Name: Mobile Concierge Service
Service Version: 2.0.0.37
Service Name: Location Analytics Service
Service Version: 1.0.0.12
Server Monitor
Server start time: Fri Mar 01 15:59:43 CET 2013
Server current time: Mon Mar 04 09:39:45 CET 2013
Server timezone: Europe/Ljubljana
Server timezone offset: 3600000
Restarts: 6
Used Memory (bytes): 66655704
Allocated Memory (bytes): 133169152
Max Memory (bytes): 477233152
DB virtual memory (kbytes): 0
DB virtual memory limit (bytes): 0
DB disk memory (bytes): 2137466496
DB free size (kbytes): 0
Active Sessions
Session ID: 16978
Session User ID: 1
Session IP Address: 10.13.7.15
Session start time: Mon Mar 04 09:38:17 CET 2013
Session last access time: Mon Mar 04 09:38:19 CET 2013
Default Trap Destinations
Trap Destination - 1
IP Address: 10.13.7.5
Last Updated: Fri Mar 01 11:43:04 CET 2013
Total Active Elements(Wireless Clients, Tags, Rogue APs, Rogue Clients, Interferers, Wired Clients): 25
Active Wireless Clients: 13
Active Tags: 0
Active Rogue APs: 11
Active Rogue Clients: 1
Active Interferers: 0
Active Wired Clients: 0
Active Elements(Wireless Clients, Rogue APs, Rogue Clients, Interferers, Wired Clients, Tags) Limit: 100
Active Sessions: 1
Wireless Clients Not Tracked due to the limiting: 0
Tags Not Tracked due to the limiting: 0
Rogue APs Not Tracked due to the limiting: 0
Rogue Clients Not Tracked due to the limiting: 0
Interferers Not Tracked due to the limiting: 0
Wired Clients Not Tracked due to the limiting: 0
Total Elements(Wireless Clients, Rogue APs, Rogue Clients, Interferers, Wired Clients) Not Tracked due to the limiting: 0
Context Aware Sub Services
Subservice Name: Aeroscout Tag Engine
Subservice Name: Cisco Tag Engine
Jelena
ā03-06-2013 06:52 PM
I was under the impression that you don't interface directly with MSE, all configuration/monitoring activities with MSE are done through WCS/NCS once you have successfully bound the two together?
Someone correct me if I am wrong in this assumption.....
ā03-06-2013 06:54 PM
You are correct, but I think it was an initial error that they were seeing and wanted to know what's wrong.
ā03-06-2013 11:04 PM
We are able to manage MSE trough Prime Infrastructure 1.3, but we would like to see Location Analytics user interface.
In guide
says:
To log into Location Analytics user interface through a web browser, follow these steps:
In the address line of browser, enter https://location-analytics-ip-address, where location-analytics-ip-address is the IP address of the Location Analytics server. Location Analytics user interface displays the User Login page.
But when we do that we are getting error that I have posted earlier.
We have tried to import certificate in MSE but when we are importing server certificate we are getting message that private key is not find in folder /root/TestFolder/sertificate.cer. (Please see picture below)
We have followed procedures explained in
https://supportforums.cisco.com/docs/DOC-12775 to append private key to the signed certificate ,and we have also tried these commands:
Combine the CA.pem certificate with the private key, and then convert the file to a .pem file.
Issue this command in the OpenSSL application:
openssl> pkcs12 -export -in CA.pem -inkey ' mykey.pem ' -out " CA.p12 " -clcerts -passin pass:check123 -passout pass:check123
openssl> pkcs12 -in ' CA.p12 ' -out " final.pem " -passin pass:check123 -passout pass:check123
for appending private key to the certificate but we are still getting the same message when importing certificate.
When we type http://mseipaddress:8080/ui we are able to see login page but we can't authentificate.
Is there something that we should do to get Location Analytics web services up and running.
Thank you for replays.
Jelena
ā03-13-2013 12:53 AM
I am having the exact same problem when trying to import the Server certificate. In addition I am unable to even get MSE talking to Prime Infrastructure 1.3 - I have tried re-installing both MSE and Prime Infrastructure several times but to no avail. Prime Infrastructure 1.2 and MSE 7.3 worked fine.
ā03-13-2013 01:57 AM
We have managed to login with MSE.
http://
We couldn't login with default user admin so we have defined new user in Prime and with that user we have managed to login to Location Analytics, but it is working only in Chrome browser, in any other we can see login page but when we enter username and password we don't get anything, login page is just refreshed and that's all. We have got the same behavior when we tried to log in with default admin user.
So after defining new user in Prime and enabling legacy HTTPS we can now login to MSE but only from chrome browser.
Jelena
ā03-13-2013 01:24 AM
Jelena,
what credentials are you trying to use when you login in? http://
try username: admin and password: admin as this is the default.
Post Back...
Mark
