Monitor cisco Access point
Ahmed Zniti
Community Member
i want to monitor cisco access point using SNMP .These WAP are controlled by two Cisco Controllers (In HA mode ‘Active/Passive)and the  protocol used for Controller-WAP communication is CAPWAP . Is that possible or not
Somtehin Else  can we find an OID or monitor which can calculate  signal strength (Weakness) on cisco Controllere wireless or access points ?
Ahmed
Leo Laohoo
Yes you can.  SNMP is the underlying protocol used by Cisco Prime Infrastructre.
Exactly WHAT are you trying to do/achieve?
HI
I would like to supervise the access points and the controller by monitoring application and I would like to know how to enable snmp in the access points(for the case of capwap AP) is that through the controller or independently whether the WLC contains the  OID of signal strength (Weakness)
