Monitoring CA certificate on webauth
PSM
We are using CA provided certificate for Webauth on wireless controllers for guest portal. The challenge we facing are we are not able to monitor the status og certificate from internal infra as the certificate is part of guest network local on the site. I tried to find if WLC is generating any warning before certificate is expired but could not find that.  Does anyone has knowledge in this regard ?
  The WLC does not have SNMP trap for expired certificates.  I dont think you can monitor this.
balaji.bandi
Is this Public Cert or Internal Certificate,  we made custom  script, which checks internal and external cert and generate email alert 90 - 60 -30days so on.
BB
Rich R
What WLC? What version of software?
Regardless - there's a very simple solution.
When you buy the cert you know what the expiry date is so add 1 or more reminders in your diary, copying as many people as you want, to ensure that everyone who needs to know gets reminded in good time that the cert is due to expire on a certain date and can get it  renewed before then.
