Nearby APs in running configuration
I have seen the Nearby APs detail in Cisco WLC show run-config
Nearby APs
AP 5c:50:15:25:6b:3f slot 1.................. -95 dBm on 157 40MHz (X.X.X.X) AP-TEST-1
What this line showing? within brackets the IP address mentioned.
Sandeep Choudhary
showing the nearby AP for a clinet:
5c:50:15:25:6b:3f - MAc address of AP
Slot1: 5 Ghz Band
-95 dBm - RSSI
157 - Channel Number
40MHz - Channel Width
X.X.X.X - IP of AP
AP-TEST-1 - AP Name.
Dont forget to rate helpful posts
Hi Sandeep
Thanks for the reply but some terms are not correct.
x.x.x.x is not showing IP address of AP. It is showing IP address of WLC.
and MAC address is neither ethernet MAC address of AP nor MAC address of Radio bands.
The last two hex of the mac address change, based on the ssid in some cases. Not sure if that is true here, but keep that in mind.
