Next RADIUS if fail authentication
adrien.dupont
Frequent Visitor
Frequent Visitor
Hello everyone,
I try to configure a kind of Fallback RADIUS, I explain :
Il want two radius server in my WLAN :
- In one RADIUS, we have serveral users (first AD)
- In the other one, we have the rest of our users (second AD)
Is it possible to switch to RADIUS n°2 if we have a fail with the server one. If I understand, the fallback option is use when the server is down (unrecheable) but if we have a fail authentication ?
Thank's
Adrien Dupont
Rasika Nayanajith
NO,
You get Access-Reject from first RADIUS server & that's pretty much it. Only first sever fails WLC use backup server.
Rasika
5 Replies 5
Rasika Nayanajith
NO,
Rasika
So it's not possible on Cisco WLC. I just want to compare with a another manufacturer, we have this option :
fail-over: Fail-over is always enabled. Fail-over means is that if the first auth-server is not reachable (time-out), the second server will be checked. That is the difference between fail-over and fail-through
But not this one :
allow-fail-through: When this option is configured, an authentication failure with the first server in the group causes the controller to attempt authentication with the next server in the list. The controller attempts authentication with each server in the ordered list until either an authentication is successful or the list of servers in the group is exhausted.
Thank you for your reply !!
Adrien Dupont
Yes, in Cisco WLC, fail over works  when primary RADIUS is not reachable/ or responding.
Rasika
Hi Can you please check the following and assist?
https://supportforums.cisco.com/discussion/13326296/configuring-radius-server-authenticating-specific-ssid
patoberli
See here for some tuning parameters:
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/118703-technote-wlc-00.html
