No SSID broadcasting
sajid231088
Level 2
Level 2
dear All,
hope you all are doing well.
i have one query, we have a one wireless setup having Cisco 5508 WLC and 180 numbers of Cisco 1702i AP.
this is centralized setup all APs are installed at different location or we can say installed at different cities.
setup has been a month all were working fine but recently client informed us that at some location Access points are not showing the SSIDs.
AP LED status Red,Blue & Green alternately blinking.
we tried to ping from the AP to WLC vice versa, the result was successful.
Reset and reboot the AP but no solution.
please help me to resolve this.
why this is happening ? Where is the issue ?
6 Replies 6
Sandeep Choudhary
check the AP groups on WLC.
Maye be these AP are assigned to diff. AP group.
https://rscciew.wordpress.com/2014/01/22/configure-ap-groups-on-wlc/
Don't forget to rate helpful posts
Dear Sandeep.
Thanks for your reply.
issue resolved or still facing problem ?
Dear Sandeep,
thanks for your help. issue has been resolved.
LED Status Indications
Message
Type
Status
LED
Message
Meaning
Boot loader status sequence
Blinking green
DRAM memory test in progress
DRAM memory test OK
Board initialization in progress
Initializing FLASH file system
FLASH memory test OK
Initializing Ethernet
Ethernet OK
Starting Cisco IOS
Initialization successful
Association status
Chirping Green
Normal operating condition, but no wireless client associated
Green
Normal operating condition, at least one wireless client association
Operating status
Blinking amber
Software upgrade in progress
Cycling through green, red, and amber
Discovery/join process in progress
Rapidly cycling through red, green, and amber
Access point location command invoked
Blinking red
Ethernet link not operational
Boot loader warnings
Blinking amber
Configuration recovery in progress (MODE button pushed for 2 to 3 seconds)
Red
Ethernet failure or image recovery (MODE button pushed for 20 to 30 seconds)
Blinking green
Image recovery in progress (MODE button released)
Boot loader errors
Red
DRAM memory test failure
Blinking red and amber
FLASH file system failure
Blinking red and off
Environment variable failure
Bad MAC address
Ethernet failure during image recovery
Boot environment failure
No Cisco image file
Boot failure
Cisco IOS errors
Red
Software failure; try disconnecting and reconnecting unit power
Cycling through red, green, amber, and off
General warning; insufficient inline power
George Stefanick
When you see the blinking we call that in the hunt. The AP gets an IP address, which is why you can ping. Then the AP blinks those lights cause it trying to find the WLC.
How are you set up to allow the AP to find the controller?
