Number of SSID's on a H-REAP AP
vanderwaalr
What is the maximum number of WLANs/SSIDs that can be configured on a H-REAP access point?
I have a network with 3502i AP's, centralised WLC's in the data centre running 7.0.116.0, and WCS version 7.0.172.0.
I was successfully running 2 SSID's at a remote site, one SSID was configured for H-REAP local switching, dropping out to the local site VLAN X, and the other SSID was a central switching guest WLAN anchored to a WLC in a DMZ.
I configured a third SSID at the local site running H-REAP local switching, and now I cannot see the guest SSID anymore, it does not appear to be broadcasting.
Is there a maximum of 2 WLANs/SSIDs when operating in H-REAP mode?
The SSID's are configured as follows:
H-REAP SSID #1 is WPA2 AES 802.1x
H-REAP SSID #2 is WPA2 AES 802.1x
Guest SSID is WPA2 PSK + Layer 3 Web Authentication
Thanks.
Surendra BG
MAX WLAN or the SSID that u can go on a AP is 16... ur scenario should work unless there is a config issue!!
Surendra
Surendra BG
5 Replies 5
Surendra BG
Surendra
Surendra BG
Surendra,
Thanks for the response.  So the maximum number fo 16 doesn't matter if H-REAP mode is enabled or not, regardless of the AP and/or SSID mode, the maximum WLANs/SSIDs on an AP is 16?
For some reason I thought there was a limit on the number of SSIDs that could be enabled on an AP when the AP is in H-REAP mode.
Thanks.
Since ur using the latest, the SSID number doesnot matter..
Surendra
Surendra BG
OK, thanks.  I guess it must be a configuration issue.
I'll go investigate.
Just to follow up for others out there.
In the end I had to remove the new WLAN/SSID mapping in the AP Groups section and then re-add it.  As soon as I did that, the SSID started broadcasting again.
