Password Problem with RV340W
dgrazulis@qcc.mass.edu
Community Member
I just got a Cisco RV340W Umbrella.  In trying to set it up the directions say that both the username and password are cisco.
When I go to the address listed (192.168.1.1) and enter the given passwords I get an error stating that they are incorrect.  I've tried the reset button but get the same results.
Any Suggestions?
5 Replies 5
balaji.bandi
STEP5. Enter the username and password. The default username is Cisco. The default password is cisco. Passwords are case-sensitive.
BB
This doesn't help as by entering the default username (cisco) and the default password (cisco) generates the same error - Invalid username/password.
Try a different browser? see if that can make any difference. Can you post the screenshot what is the error you getting?
BB
I've tried both Firefox and Edge. I get to the login screen, enter the default username nd password (both are cisco in lowercase) and iI get an error stating the username and/or password are incorrect. I've tried the Reset but still get the error.
Then contact Cisco support or your supplier for assistance.
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
AP supported channel lookup: https://apchannels.cisco.com/
