PEAP-GTC and roaming
mirek.tichy_2
Is it possible to use PEAP-GTC without re-entering credentials after the client roams?
Configuration is as follows
RSA RADIUS, SecurID tokens
WLC 2106 4.2, LAP1131
Dell 630, Intel 3945abg, Windows XP
Juniper Odyssey 4.52
WPA TKIP
CCKM enabled on the WLAN
5 Replies 5
Richard Atkin
Level 4
Level 4
There's a caching option under the "Security" tab on the WLC that's supposed to achieve this goal, although I've never used it myself.
Richard
The checkbox that Rik is referring to is "credentials caching enabled". This caches credentials on all access points local to the client to increase roaming times by forcing only a reassociation and not a reauthentication. Reassociations are much faster than reassociations and reauthentications.
Hi, thanks a lot. I know the "credentials caching" checkbox but it was removed in 4.2 version.
coolccnp
Everything I know of PEAP it does not support Fast Secure Roaming (CCKM).
sringer
similar setup here...
PEAP
RADIUS
SecurID tokens
Odyssey 4.7
4402 4.1.171
LAP1131
WPA/WPA2 TKIP (no CCKM)
Clients roam just fine, no need to re-authenticate. Using 4.1.171, but without the credentials caching or CCKM,
