PEAP
ney25
Level 7
Level 7
hi ,
anyone can help ?
EAP-TLS or PEAP authentication failed during SSL handshake
regards
kitten
Hi Fynskisb16,
thanks for ur information, that's really helpful for me.
i have another question about the WDS and WPA2. becaues, i noticed when i implement WDS , those whose are using PEAP/WPA2 was affected . they can't even connect to network.
thanks
What type of AP's are you using? If lwapped from IOS they don't support WDS. Hope this helps.
Access points converted to lightweight mode do not support Wireless Domain Services (WDS). Converted access points communicate only with Cisco wireless LAN controllers and cannot communicate with WDS devices.
http://www.cisco.com/en/US/docs/wireless/controller/3.2/configuration/guide/c32lwap.html
