Power Adaptor AIR-PWRADPT-RGD2 for AP C9124AXE-ROW
I can't find the Power adaptor AIR-PWRADPT-RGD2 in the CCW, any update and which part number to use for access point C9124AXE-ROW
5 Replies 5
marce1000
  - Ref : https://www.zenitel.com/sites/default/files/2023-11/C9124AX%20Hardware%20Installation%20Guide.pdf
  >...The Cisco Catalyst 9124AX Series Outdoor Access Point supports the following DC power adapters::
• PID AIR-PWRADPT-RGD2=
         Seems to be the only model supported ,
 M.
I only see AIR-PWRADPT-RGD2U= in CCW, which is with US AC connector.
Differences between Cisco AIR-PWRADPT-RGD2 and RGD2U
The adapter AIR-PWR-ADPT-RGD2 has a “pig tail” for the AC power entry (designed to be wired to a source of AC) while the AIR-PWR-ADPT-RGD2U has a plug assembly (NEMA 5-15P) installed for use in most power sources in North America.
Check with Cisco Pre-sales support / Sales account team for correct Part number for ROW AP.
Jagan Chowdam
/**Pls rate useful responses**/
Rich R
From https://www.cisco.com/c/en/us/products/collateral/wireless/catalyst-9100ax-access-points/nb-06-cat9124-ser-ap-ds-cte-en.html#Productspecifications
Input power requirements
●  802.3af Power over Ethernet (PoE), 802.3at PoE+, 802.3bt PoE++, Cisco Universal PoE (Cisco UPOE)
●  Cisco power injector, AIR-PWRINJ-60RGD1= and AIR-PWRINJ-60RGD2=
●  Cisco power injector, AIR-PWRINJ6= (Note: This injector supports 802.3at)
●  DC power source: Auxiliary DC input, 24V to 56V
AIR-PWRINJ-60RGD1= Power Injector, 60W, outdoor, North America plug
AIR-PWRINJ-60RGD2= Power Injector, 60W, outdoor, global version without AC plug
AIR-PWRADPT-RGD2U= Power Adapter for AP, US AC connector
So as others have pointed out if you want to use the power adapter then simply order the U variant and cut off the US connector to install with your own or to wire in directly as required.  You could also use a power injector.
Gaurav  Kansal
I already quoted that yesterday ^^^ @Gaurav Kansal  <wink>
