prime, heatmap issue
Bruno Dinis
Level 4
Level 4
Hello all, I've been facing a issue regarding a wireless coverage in a certain area.
(printscreen on 27th march)
As you can see, the top left corner AP isn't "heating" the map as other AP's do.
Although i've been using covera to measure the signal near the AP and I've measure -30 dBm, I was standed next to the AP, so for me, the AP is up and running, and for Prime Map is not!
I've been searching and there was a Minor alarm in the AP, Noise threshold violation reported by '802.11b/g' interface of AP 'xx-ap06', connected to the controller name 'wlc'.
Any thoughts on what's going on with this AP in particular?!
Today (31st march) I realize that the heatmap changed again
(printscreen on 31st march)
Cheers
patoberli
This looks interesting. What have you selected on the left menu? And can you enable the showing of the signal strength?
