Problem configuring CW9178I for Mesh
Hello Community,
I'm struggling to get my CW9178I APs meshing on my 9800-L-F. I have followed a Configuration Guide from YouTube, but I am stuck at the part where i am supposed to classify the "AP Mode - Bridge" and "Role - Root/Mesh". I cannot find anywhere in the GUI where I can specify these parameters.
This led me to looking for more cisco documentation on setting up mesh. I was looking for any other mesh configuration guides, either through the GUI or CLI. I couldn't find anything better than the YouTube video I was following. However it did add to my confusion, because I cam upon a Feature Matrix for Cisco Wireless Access Points document that says the the CW9178 cannot do "Mesh Mode" (Image Attached Below).
Any guidance on how I could move forward is appreciated.
Mark Elsen
  - @Bradley Rousseau    That is probably true (no mesh support) for those models, because they are designed for
                                        local use.
                                        Seems to be confirmed with : https://www.cisco.com/c/en/us/support/docs/wireless/catalyst-9800-series-wireless-controllers/215100-join-mesh-aps-to-catalyst-9800-wireless.html#toc-hId--1791301994
                                              >....This example uses lightweight access point (1572AP and 1542)
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
                                        local use.
  M.
       Beauty and terror
      Just keep going
       No feeling is final
Rich R
Yes that table is from https://www.cisco.com/c/en/us/td/docs/wireless/access_point/feature-matrix/ap-feature-matrix.html#_Toc205553644
Sometimes mesh support will come in a later release depending on customer demand, but generally only the outdoor APs come with mesh as default.
But in Cloud Managed (Meraki) mode it apparently can support repeater mode (Meraki term for mesh) so that's something to consider if you need the feature:
https://documentation.meraki.com/MR/Install_and_Get_Started/Installation_Guides/CW9178I_Installation_Guide#Basic_Troubleshooting
Please click Helpful if this post helped you and Accept as Solution if this answered your query.
TAC recommended codes for AireOS WLC's   and   TAC recommended codes for 9800 WLC's
Best Practices for AireOS WLC's,   Best Practices for 9800 WLC's   and   Cisco Wireless compatibility matrix
Check your 9800 WLC config with Wireless Config Analyzer using "show tech wireless" output or "config paging disable" then "show run-config" output on AireOS and use Wireless Debug Analyzer to analyze your WLC client debugs
Field Notice: FN63942 APs and WLCs Fail to Create CAPWAP Connections Due to Certificate Expiration
Field Notice: FN72424 Later Versions of WiFi 6 APs Fail to Join WLC - Software Upgrade Required
Field Notice: FN72524 IOS APs stuck in downloading state after 4 Dec 2022 due to Certificate Expired
- Fixed in 8.10.196.0, latest 9800 releases, 8.5.182.12 (8.5.182.13 for 3504) and 8.5.182.109 (IRCM, 8.5.182.111 for 3504)
Field Notice: FN70479 AP Fails to Join or Joins with 1 Radio due to Country Mismatch, RMA needed
Field Notice: FN74383 APs Running 17.12.4/5/6/6a May Run Out of Flash Space Preventing Upgrades
How to avoid boot loop due to corrupted image on Wave 2 and Catalyst 11ax Access Points (CSCvx32806)
Field Notice: FN74035 - Wave2 APs DFS May Not Detect Radar After Channel Availability Check Time
Leo's list of bugs affecting 2800/3800/4800/1560 APs
Default AP console baud rate from 17.12.x is 115200 - introduced by CSCwe88390
